Looks good Dejan, see you got the 2 PDC bit working.
SWEET!!! looks the dogs!!! how does the front n rear sensor bits work n is the ready to get complete yet?
cheers
Baz
I suspect the issue may not be whether Robby can change the serial or PID of the PDC kit, but that the xmitters for both kits will have duplicate IDs. so the receivers will not be able to distinguish between the two kits.
(Of course I may be wrong and the kits all have a unique frequency amd/or ID)
Anyone with two kits able to try this ?
I think Wireless connection is not posible but If we connect it by wire then we don't have this problem and is problem only PIC(I think)...
P.S. I have at home two builded kits and I will try in next days![]()
Failing that, you could have one wired and one wireless.
That might even be better as the control units will be at opposite ends of the car anyway.
Good point, would have to stop power getting to the transmitter.
