Page 29 of 45 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 281 to 290 of 445
Like Tree4Likes
Thread: Custom USB Parking Sensor interface (formally PDC-USB)
  1. #281
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Robby, is it possible to program a delay into your plugin? Every time I start the car and put the car in drive it switches to the camera view and stays there, even if the shifter is in drive. Sometimes it freezes Road Runner. Maybe 1 to 2 sec delay would be good, because every automatic has to goto reverse, neutral and then to drive.
  2. #282
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by MGD View Post
    No problem MGD, I'm just working on a new release of the plugin, so I can add also this new feature.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  3. #283
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Great to hear Robby, take you time, thanks.
  4. #284
    Oct 2006
    Moscow ZAO, Russia
    RB0 (used to drive a beeper) is multiplexed with SDA which makes I2C sensor devices out of scope. I've analyzed quite a few $30 devices (shipped to EU and US under different brands), including two models Robby was playing with.
    SO .. in the next PCB release I propose to go beep on PORTA which is also nice to drive LEDs trough 330 oHm resistors .. just a thought.
    Going to higher frequences than 8MHz would also be nicer cause RC2 can only be used for polling when it is not PWM, so higher sampling rate may be useful.
    Great work overall Robby, inspirational.
    Will contract for C++/Win-Linux/PIC jobs
  5. #285
    Newbie astraologo's Avatar
    Aug 2007
    Italy
    Hey guy I have same problem with the plugin for CF2.0, the hardware works perfectly because i use it in RR , but in CF the display appears for few second and disappears. Idea of solution? i post the pdc.log file for vision.
    Attached Files Attached Files
    mobo asrock K7S41gx- Amd atlon 1,2Ghz -512Mb ram- hd 2,5" 160Gb- lilliput 7" 619 touch-gps Holux- bluetooth digicomm palladio-usb park assist (RRPDC) -obdII elm327-hubusb trust
  6. #286
    Feb 2007
    Hi, I'm building one interface, all is done but it miss the bin file to flash the PIC, do you have an idea where can I found one?
    I use the normal LED PDC kit and not using wireless.
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by AzN_Tuan View Post
    You can't get it. You must order programmed PIC from Robby BMW.
  8. #288
    Feb 2007
    Ok thanks, can I just buy the software?
    I already have the PIC, I don't really need one and I don't want to wait the shipping delay.
  9. #289
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    I think no, because then you can "resell" it... Contact him...
  10. #290
    Feb 2009
    Come poso comprare tuo PIC programato?
    Ciao ROBBY scusa che scrivo in italiano ma mio inglese non e acetabile meglio italiano, sono polacco fra 2 setimane vengo in italia Emiglia romagna (FC) voglio sapere come poso comprare tuo pic programato me interesa moplto tuo progetto ho machina lunga come treno e uso carputer poso comprare parc sesnsor con LED e era belissimo avere interface per carputer ma non so come contatare con te se me puoi rispondere sara belissimo dtcpaolo(chiociola)interia.pl sei un grande veramete fai cose No.1 oggi ho pensato che nensuno non ha messo riscaldamento negli protezioni di parafangi come qui che ce molto neve tutto si tappa con fango di neve gomme non si posono pulire sogno sempre piene di neve penso che metendo riscaldamento che siolga neve dentro parafango ci cava quel probleme se non pulisci e tutto si giacia congela pensa te come devi sforzare sterzo per girare ruote non so se buona idea forsce non per tutto mondo ma nord si saluti fai piu di belle cose sei bravo!
  1. Replies: 115
    Last Post: 03-05-2011, 03:54 AM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  5. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
