Page 32 of 45 FirstFirst ... 222324252627282930313233343536373839404142 ... LastLast
Results 311 to 320 of 445
Like Tree4Likes
Thread: Custom USB Parking Sensor interface (formally PDC-USB)
  1. #311
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    now i'm just waiting for a complete kit from dejan....
    got an idea... is it possible to blend a picture over the feed from the cam? could be very usefull so that you could draw guidelines that shows where the car would go, could imagine this would be very helpfull on parking lots where the spaces are just painted and there is nothing to messure distance against
  2. #312
    Dec 2007
    Sydney Australia
    Hi Robby,
    Just starting to put together my carputer and this is awesome !
    I have an 8 sensor (4 front + 4 rear) parking assist unit in my car and it seems to be a similar model to your first system in the first post of this thread going by the case markings. It is a wired display and similar to the following unit on ebay 8-sensor parking display.
    My question is...
    If I do a scope trace of the signals it uses, could you do a custom PIC for me which does the full front+rear in the one interface ?
  3. #313
    sdh
    sdh is offline
    Jan 2009
    Will this one work with PDC
    The parking sensory avaialble here locally have 6 wire connection the the display unit. 2 wires carry power and ground and I am not sure what the rest of the 4 wires carry. The display unit is LED type and has almost same chips and construction given in the first few posts except the RF module. Any clue if this can work with PDC. I am attaching the picture of the controller board and the three main ic's are:
    IC3: NXP HEF4052BT
    IC4: ON Semi 14013BG
    IC5: TI TL084C
    The display unit is based on Atmel AT 89C2051
  4. #314
    Oct 2009
    Hi All,
    I sent a PM to Robby but still no answer... I need a PIC.. (I'm Italian)
    Thanks!!
  5. #315
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Could someone please clarify how front & rear PDC is done.
    - Do i need 2x 4 sensor kits, or 1x 8 sensor?
    - Do i need 2x the USB-PDC boards, or one?
    TIA HoSS
  6. #316
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by HoSS View Post
    TIA HoSS
    You are right.
    You need:
    2x USB PDC kit with diferent version of PIC
    2x 4sensor kits one you must have connected by wire
    Im say how to do this min cca. 2-3x...
  7. #317
    Oct 2009
    Quote Originally Posted by _Dejan_ View Post
    If you need "source code" for PIC you will not receive it
    Hi Dejan,
    I need a programmed PIC to mount on my board..
    could be possible??
  8. #318
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by Markil View Post
    Hi Dejan,
    could be possible??
    Sorry I can't provide you only PIC. Why? Because I have only 2 and Robby will not be back until december and then I can't sell my boards, which I have at home...
    Best regards, _Dejan_
  9. #319
    Oct 2009
    Ok...............
    I'll wait till Robby returns..
    regards...
  10. #320
    May 2008
    My understanding is 2 x USB PDC boards (one has a slightly different PIC software). Each board runs 4 sensors.
    ** Edit ** Dejan beat me to it !
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  5. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
