To run back and front.
At least one has to be run wired.
You can not run both wirelessly as the sensors from both units will xmit on the same frequency with the same ID.
Printable View
Hi,
Do you need it for front or rear system? Which front end you will use? Centrafuse or RR?
I have avalible only V1.10 which is designet do use with front system but in Centrafuse can be used as rear, because you can select which device you will use for rear system and which for front. Im not shure if in RR is this possible... If you are interested send me PM...
Best regards, _Dejan_
Dejan... tell me you dont have a list of people waiting for december to roll around :). I cant wait til ya have some back in stock!
what happens if i connect one front and one back (each with the right pic inside) and power them up at the same time.. will the plugin show the graphic beam thing only at the back of the car or will it show at the front also? have some tried to install both modules and can provide some screenshots?
Hello!
Very interessting System like also USB-TPMS! :thumb:
@_Dejan_:
On what date i can order the complete kit (incl. 3rd eye) again from you?
EDIT: PM Sent to _Dejan_!
thanks,
greetings,
Ottmar
Quote:
Originally Posted by _Dejan_
Did the board make even for PDC and TPMS but where do I get the firmware for the PIC 18F2550 microcontroller.
I can translate it through Google, sorry if it looks funny.
mfg
Lordin
I have following parking sensors kit - http://cgi.ebay.com/ebaymotors/ws/eB...m=230403680925
It is already wired and working just fine as standalone. Could I just replace the processor unit to support PDC-USB? Which two main units should I take to support those sensors and be able to integrate with USB kit? Please advice.
Any idea which is minimal and maximum distance those can measure?
What about Linux/OpenICE/nGhost support?
i think there is non so far
