Page 33 of 45 FirstFirst ... 232425262728293031323334353637383940414243 ... LastLast
Results 321 to 330 of 445
Like Tree4Likes
Thread: Custom USB Parking Sensor interface (formally PDC-USB)
  1. #321
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    To run back and front.
    At least one has to be run wired.
    You can not run both wirelessly as the sensors from both units will xmit on the same frequency with the same ID.
  2. #322
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by Markil View Post
    Ok...............
    I'll wait till Robby returns..
    regards...
    Hi,
    Do you need it for front or rear system? Which front end you will use? Centrafuse or RR?
    I have avalible only V1.10 which is designet do use with front system but in Centrafuse can be used as rear, because you can select which device you will use for rear system and which for front. Im not shure if in RR is this possible... If you are interested send me PM...
    Best regards, _Dejan_
  3. #323
    Oct 2009
    Quote Originally Posted by _Dejan_ View Post
    Hi,
    PM sent! Thanks!!
  4. #324
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Dejan... tell me you dont have a list of people waiting for december to roll around . I cant wait til ya have some back in stock!
    Live mp3Car Facebook Chat
  5. #325
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    what happens if i connect one front and one back (each with the right pic inside) and power them up at the same time.. will the plugin show the graphic beam thing only at the back of the car or will it show at the front also? have some tried to install both modules and can provide some screenshots?
  6. #326
    Nov 2009
    Hello!
    Very interessting System like also USB-TPMS!
    @_Dejan_:
    On what date i can order the complete kit (incl. 3rd eye) again from you?
    EDIT: PM Sent to _Dejan_!
    thanks,
    greetings,
    Ottmar
  7. #327
    Dec 2009
    Reported Post by lordin
    Quote Originally Posted by HoSS View Post
    Could someone please clarify how front & rear PDC is done.
    - Do i need 2x 4 sensor kits, or 1x 8 sensor?
    - Do i need 2x the USB-PDC boards, or one?
    TIA HoSS
    You are right.
    You need:
    2x USB PDC kit with diferent version of PIC
    2x 4sensor kits one you must have connected by wire
    Im say how to do this min cca. 2-3x...
    Did the board make even for PDC and TPMS but where do I get the firmware for the PIC 18F2550 microcontroller.
    I can translate it through Google, sorry if it looks funny.
    mfg
    Lordin
  8. #328
    riv
    riv is offline
    Dec 2009
    I have following parking sensors kit - http://cgi.ebay.com/ebaymotors/ws/eB...m=230403680925
    It is already wired and working just fine as standalone. Could I just replace the processor unit to support PDC-USB? Which two main units should I take to support those sensors and be able to integrate with USB kit? Please advice.
    Any idea which is minimal and maximum distance those can measure?
  9. #329
    riv
    riv is offline
    Dec 2009
    What about Linux/OpenICE/nGhost support?
  10. #330
    Oct 2008
    Odense, Denmark
    i think there is non so far
    Blessed are the "cracked" for it is they who let in the light.
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  5. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
