You will not find source for PIC. You must contact Robby if you want order already programmed PIC.
Printable View
There is no source.
RobbyBMW created it and is the only one with the source, he won't give it away, but I'm sure you can purchase a programmed PIC from him
How can I contact Robbie? I've tried with email and PM on this foruma, but him do not answer. Maybe there is another way?
Many thanks
Giuliano
Hi All;
I have a problem about configuration of pdc for centrafuse.I finish to connections and start to ps holmes.Everything ok and normal.But whan I start to centrafuse I can't use PDC plugin and It ignore itself.whan I start it didn't see sensor signals.I record video with version: 2.0.5.0 but ther is a same problem with 2.1.5.0 I dont understand what is the problem.Anybody help me please what can I do resolve for this problem...You may watch from here -->> http://www.youtube.com/watch?v=FKkUw0XIqms
Hi all;
I have a new problem.I have 2 pic kit for pdc(v1.00 and v1.10).I try with psholmes everything working perfect but front sensor not working with centrafuse.(I have centrafuse2 and front pic selected PID=3.0 in pdc settings).I dont understand what is the problem.I record video about this problem you may see...I am waiting your help...Thanks alot seeyou...
http://www.youtube.com/watch?v=AirM5s3mQM0
Hi again;
I turned off rear sensor and tryed only front sensor with centrafuse.Same poblem continues...Front sensor work with psholmes perfectly but can't with centrafuse.I tried with all the pdc.ddl files in forum but can't see front sensor.Anybody can use front sensor with centrafuse? If use wich version of centrafuse and wich pdc.ddl files ? Help me please...Thanks alot...
