Page 39 of 45 FirstFirst ... 2930313233343536373839404142434445 LastLast
Results 381 to 390 of 445
Like Tree4Likes
Thread: Custom USB Parking Sensor interface (formally PDC-USB)
  1. #381
    Oct 2006
    Moscow ZAO, Russia
    Quote Originally Posted by boelle View Post
    figured it... just de-select everything but the parking assist option...
    now could be nice to make a real RR plugin for this. but need some sourcecode for that
    Sure. If it comes to direct integration with the system library that talks to USB device,
    here is all you might need. No prob to provide other parts of sources, will just
    find a way to clean & publish it.
    C++ SDK installable as a package from http://www.novorado.com/setup.exe
    Documentation http://novorado.com/SDK/doc/classNov...arktronic.html
    For C# integration, we've used simplified sub-set of functions (see park.cpp -> novopdc.dll) to export
    into VS environment, in a proxy dll called novopdc.dll (which is Robby's slightly modified source).
    You might explore it with dependency walker.
    POSIX threading mechanics is used on top of GCC / MINGW C++ source code,
    which makes C++ not directly mappable into VB6 due to name mangling, memory management
    conventions. However by using a proxy DLL (novopdc.dll) all those issues are successfully sorted out.
    C# application is more or less functional.
    pa_init() initializes datastructures, and connects to the device. (It can be done later when USB is plugged)
    pa_head_distance(int i) is used to get distance of a particular sensor
    pa_poll() loads update from a device
    pa_ping() checks device is connected - beeps with internal buzzer and blinks LEDs
    pa_hide_delay() reads registry set parameter for inactivity delay (parker.exe)
    pa_head_visible(int i /* 0-7 */) identifies if particular sensor is enabled (can be disabled by user if mechanically broken)
    NOVOPDC.DLL is already included in installation package. You just need to add few lines of code to C#/VB to access it.
    C# glue code for importing described methods from system DLL.
    Code:
            #region NOVOPARK
            [DllImport("novopdc.dll", EntryPoint = "pa_init")]
            public static extern int pa_init();
            [DllImport("novopdc.dll", EntryPoint = "pa_poll_interval")]
            public static extern int pa_poll_interval();
            [DllImport("novopdc.dll", EntryPoint = "pa_ping")]
            public static extern int pa_ping();
            [DllImport("novopdc.dll", EntryPoint = "pa_head_visible")]
            public static extern int pa_head_visible(int id);
            [DllImport("novopdc.dll", EntryPoint = "pa_head_distance")]
            public static extern int pa_head_distance(int i);
            [DllImport("novopdc.dll", EntryPoint = "pa_poll")]
            public static extern void pa_poll();
            [DllImport("novopdc.dll", EntryPoint = "pa_retry_delay")]
            public static extern int pa_retry_delay();
            [DllImport("novopdc.dll", EntryPoint = "pa_hide_delay")]
            public static extern int pa_hide_delay();
            #endregion NOVOPARK
    Source code for NOVOPDC.DLL library
    Using that one, you do not have to deal with low level C++ code
    Code:
    #include	<iostream>
    #include	<fstream>
    #include	<novopark.h>
    #include	<ParkingProtocol.h>
    #include	<QStringList>
    #include	<QSettings>
    #include	<map>
    #include	<set>
    #include	<sstream>
    std::ofstream log("c:/temp/log.txt");
    // Define callback
    class Feedback : public Novorado::ParktronicUpdateCallback
    	public:
    		std::string devVersion;
    		int hasDevVersion;
    		Feedback(){ hasDevVersion=false; }
    		void load_heads();
    		void init();
    		PtrHolder<Novorado::Parktronic> m_park;
    		void poll(){
    			log << "poll()" << std::endl;
    			m_park->quant();
    		std::map<Novorado::LineId, std::map<Novorado::HeadId,Novorado::HeadLogicNumber> > m_ha;
    		std::map<Novorado::LineId, std::set<Novorado::HeadId> > m_unassigned_heads;
    		std::map<Novorado::LineId, Novorado::ParkingProtocol::PROTOCOLS> line_assignment;
    		struct Sensor{
    			bool visible: 1;
    			int distance;
    			Sensor(){ visible=false;distance=255; }
    		Sensor m_sensors[8];
    		void onNewDevice(Novorado::LineId l)
    			log << "onNewDevice(" << l <<")" << std::endl;
    		void onNewHead(Novorado::LineId l, Novorado::HeadId h)
    			log << "onNewHead(" << l << "," << h <<")" << std::endl;
    		void onDistanceChange(Novorado::LineId l, const Novorado::Pair& p)
    			log << "onDistanceChange(" << (int)(l) << ":"  << p.headId << " " << p.distanceCM << "cm)" << std::endl;
    			std::map<Novorado::LineId, std::map<Novorado::HeadId,Novorado::HeadLogicNumber> >::iterator i=m_ha.find(l);
    			if(i==m_ha.end()) return;
    			std::map<Novorado::HeadId,Novorado::HeadLogicNumber>::iterator j=i->second.find(p.headId);
    			if(j==i->second.end()) return;
    			Novorado::HeadLogicNumber h=m_ha[l][p.headId];
    			if(h<1||h>8) throw std::logic_error("Number out of bound in 'onDistanceChange(Novorado::LineId l, const Novorado::Pair& p)'");
    			log << "Writing to head " << (int)(h) << std::endl;
    			m_sensors[h-1].distance=p.distanceCM;
    		void onStatusChange(Novorado::STATUS st, std::string s)
    			log << "STATUS CODE #" << (int)(st) << " " << std::flush;
    			switch(st){
    				case Novorado::NRDP_DATA_FEED_STARTED:
    					log << "Data feed started" << std::endl;
    					break;
    				case Novorado::NRDP_DATA_FEED_STOPPED:
    					log << "Data feed stopped" << std::endl;
    					break;
    				case Novorado::NRDP_RECEIVING_DATA:
    					log << "Connected, incoming data packet" << std::endl;
    					break;
    				case Novorado::NRDP_GOT_PING:
    					log << "Gotaping" << std::endl;
    					break;
    				case Novorado::NRDP_FIRMWARE_UPDATE_MODE:
    					log << "Firmware update mode" << std::endl;
    					break;
    				case Novorado::NRDP_CONNECTING:
    					log << "Connecting to the device: " << s << std::endl;
    					break;
    				case Novorado::NRDP_NO_PARKTRONIC_SIGNAL:
    					log << "No signal: " << s << std::endl;
    					break;
    				case Novorado::NRDP_USB_CRITICAL_ERROR:
    					log << "Critical error: " << s << std::endl;
    					break;
    				case Novorado::NRDP_FIRMWARE_UPDATED_OK:
    					log << "Finished firmware update: " << s << std::endl;
    					break;
    				case Novorado::NRDP_FIRMWARE_UPDATE_FAILED:
    					log << "Unable to update the firmware: " << s << std::endl;
    					break;
    				case Novorado::NRDP_DEVICE_EMULATION:
    					log << "Emulation mode: " << s << std::endl;
    					break;
    				case Novorado::NRDP_GOT_DEVICE_VERSION:
    					log << "Received device version: " << s << std::endl;
    					devVersion=s;
    					hasDevVersion=true;
    					break;
    				case Novorado::NRDP_UNKNOWN_PROTOCOL:
    					log << "Protocol unrecognized: " << s << std::endl;
    					break;
    				default:
    					log << "STATUS " << st << ", unkown" << s << std::endl;
    					break;
    		const char** onFirmwareMode()
    			return NULL;
    static PtrHolder<Feedback> m_feedback;
    void Feedback::load_heads()
    	QSettings m_settings("Novorado","ParkingAssistant");
    	m_ha.clear();
    	QStringList groups=m_settings.childGroups();
    	log << "Loading settings, " << groups.size() << " groups" << std::endl;
    	for(int g=0;g<groups.size();g++){
    		QString grp=groups[g];
    		if(grp.left(6)=="Device"){
    			m_settings.beginGroup(grp);
    			// Get the device id
    			grp=grp.right(grp.size()-6);
    			Novorado::LineId deviceId=grp.toInt();
    			// Look for all the logic head connected to that device
    			QStringList keys=m_settings.allKeys();
    			for(int k=0;k<keys.size();k++) {
    				QString key=keys[k];
    				// spot Novorado::HeadId<x>=disabled
    				QString l=key.left(6);
    				if(l=="Novorado::HeadId"){
    					QString v=m_settings.value(key).toString();
    					l=key.right(key.size()-6);
    					Novorado::HeadId headId=l.toInt();
    					// Check if value is "disabled"
    					if(v=="disabled"){
    						m_unassigned_heads[deviceId].insert(headId);
    						log
    							<< "Disabled head - DeviceId=" << deviceId
    							<< ", Novorado::HeadId=" << headId << std::endl;
    					continue;
    				// it's probably an assignment than
    				l = key.left(9);
    				if(l!="LogicHead") continue;
    				l=key.right(key.size()-9);
    				Novorado::HeadLogicNumber num = l.toInt();
    				if(num<=0 || num>8){
    					std::stringstream ss;
    					ss << "Load heads assignment: value " << num
    						<< " is out of range";
    					throw std::logic_error(ss.str());
    				Novorado::HeadId hid = m_settings.value(key).toInt();
    				m_ha[deviceId][hid]=num;
    				m_sensors[num-1].visible=true;
    				log << "HEAD " << (int)(num) << " *** " << deviceId << ":" << hid << std::endl;
    			m_settings.endGroup();
    //	f_LogicNumbersLoaded=true;
    void Feedback::init()
    	load_heads();
    	// Tweak. Prevent from going into OSCO mode. We know the lines, it's fixed board for now
    	if(!line_assignment.size()) {
    		line_assignment[4]=Novorado::ParkingProtocol::CHALLENGER_26;
    		line_assignment[5]=Novorado::ParkingProtocol::CHALLENGER_26;
    	// Pthread 1: Launch USB ThreadProc loop
    	m_park=new Novorado::Parktronic(this,&line_assignment);
    // Initialize parking assistant
    extern "C" int pa_head_visible(int i /* 0-7 */)
    	if(i<0||i>7) throw std::logic_error("Index out of bound in 'pa_head_visible'");
    	return m_feedback->m_sensors[i].visible;
    #define	USB_POLLS_MSEC 50
    extern "C" int pa_poll_interval()
    	return USB_POLLS_MSEC;
    extern "C" int pa_retry_delay()
    	return 5000;
    extern "C" int pa_hide_delay()
    	m_settings.beginGroup("gui");
    	//m_showDelay=m_settings.value("ShowDelay","1").toInt();
    	int m_hideDelay=m_settings.value("AutoHideDelay","3").toInt();
    	return m_hideDelay*1000;
    extern "C" int pa_init()
    	try {
    		m_feedback = new Feedback;
    		m_feedback->init();
    catch( const std::logic_error& e)
    		log << "Init: Caught " << e.what () << std::endl;
    catch( ... )
    		log << "Init: unkown exception" << std::endl;
    	return 1;
    extern "C" int pa_head_distance(int i)
    	if(i<0||i>7) throw std::logic_error("Index out of bound in 'pa_head_distance'");
    	return m_feedback->m_sensors[i].distance;
    extern "C" void pa_poll()
    	// Ignore poll rquests until has device version
    	if(m_feedback->hasDevVersion) m_feedback->poll();
    extern "C" int pa_ping()
    	return 1;
    Example of interfacing with Centrafuse
    Code:
     * Park Distance Control (PDC) plugin
     * File: pdc.cs
     * Author: Dipl.-Ing. Wolfgang Otto
     * eMail: [email protected]
     * Date: August 2008
     * THIS PLUGIN IS A CONVERSION OF THE MARVELESS TOOL OF
     * Roberto Montanari, RoadRunner PDC Plugin															*
     * His VB sources are converted to C# and modified to be used as a CENTRAFUSE plugin				*
     * Thanks for his great work!																		*
     * Small Bugfixes        *
     * Fixed Camera function, higher quality car pics, working buzzer status change,                    *
     * changed german language file - Detection Distance is in cm not                                   *
     * Author: Christian Hausmann		                                                        		*
     * eMail: [email protected]        *
     * Web: www.stryder.6x.to - http://www-stud.uni-due.de/~sgchhaus/centrafuse.php (If redirection-    *
     * service is not available)        *
     * Date: July 2010        *
     * This file is subject to the condition of GNU GENERAL PUBLIC LICENSE								*
     * Therefore you are free to use this software for your own requirements and use the				*
     * source code for any modification.																*
     * The only wish is to inform the author about any kind of development.								*
    // to use the simulation mode change the complilation directive to SIMULATION
        #define _SIMULATION         // remove _ to activate
        #define _SPECIALFOLDER      // remove _ to activate
    using System;
    using System.Drawing;
    using System.Windows.Forms;
    using System.Xml;
    using System.IO;
    using System.Data;
    using System.Data.OleDb;
    using System.Web;
    using System.Collections;
    using System.Threading;
    using System.Text;
    using System.ComponentModel;
    using System.Runtime.InteropServices;
    using System.Drawing.Drawing2D;
    using System.Diagnostics;
    using System.Reflection;
    using DirectShowLib;
    using centrafuse.Plugins;
    using System.Collections.Generic;
    namespace pdc
    	public class pdc : CFPlugin
            #region Global variables
            // a small enum to record the graph state
            public enum PlayState {Stopped, Paused, Running, Init};
            // Application-defined message to notify app of filtergraph events
            public const int WM_GRAPHNOTIFY = 0x8000 + 1;
            // sound handling during buzzer sound output
            public bool bAUDIO_STOP = false;
            public bool ENABLE_AUDIO_STOP = true;
            public bool BuzzerFrontStatus;
            public bool BuzzerRearStatus;
            public struct VolumeLevelStruct
                public bool IsReduced;
                public float LastVolume;
            public VolumeLevelStruct VolumeLevel;
             * Information:
             * If the parameter useDebug is true then a lot of functions writes information
             * into a log file called pdc.log inside plugin path.
             * All errors detected by [try..catch] functions are routed to the global error.log
             * file of Centrafuse. This output can not be stopped by configurable parameter, because
             * it is a serious problem.
            public static bool useDebug = false;
            public static bool useErrorOutput = false;
            public static bool bCLOSEABLE = true;
            public static int GHoldOpenTime = 5 * 1000; // setup parameter HOLDOPENTIME
            #endregion Global variables
            #region Distance specific variables
            public enum Unit { meters = 0, inches = 1, feet = 2 }
            public static Unit DistanceUnit;
    	    public static string DistanceSuffix;
            #endregion
    		#region Video specific variables
            public static IBaseFilter VideoDevice = null;
            IVideoWindow  videoWindow = null;
            IMediaControl mediaControl = null;
            IMediaEventEx mediaEventEx = null;
            IGraphBuilder graphBuilder = null;
            ICaptureGraphBuilder2 captureGraphBuilder = null;
            PlayState currentState = PlayState.Stopped;
            DsROTEntry rot = null;
            public static bool bFullScreen = false;             // boolean value for indication full video mode
            public static bool bHeaderWritten = false;          // Date/Time Information header for error log file
            #endregion
            protected System.Windows.Forms.Timer checkTimer;
            protected System.Windows.Forms.Timer HoldOpenTimer;
            #region Sensor Data
            public struct SensorData        // Structure for distance sensors
                public byte Distance;
                public byte OldFrontValue;
                public byte OldRearValue;
            public static SensorData[] Sensor = new SensorData[8];
            #endregion Sensor Data
            #if SIMULATION
            protected System.Windows.Forms.Timer SliderTimer;
            #endif
            #region PAGE and CONFIG handling
            public static int  LENLABEL5_8 = 30;
    		public static int  LENLABEL1_4 = 40;
            public static string GLOBAL_SLIDER_PATH = string.Empty;
            public static byte SIMULATION_DISTANCE = 254;
            public const string PluginName = "PDC";
            public const string PluginPath = @"plugins\" + PluginName + @"\";
            public const string PluginPathSkins = PluginPath + @"Skins\";
            public const string PluginPathLanguages = PluginPath + @"Languages\";
            public const string PluginPathIcons = PluginPath + @"Icons\";
            public const string ConfigurationFile = "config.xml";
            public const string LogFile = PluginName + ".log";
            public static string LanguageSection = "/APPLANG/" + PluginName.ToUpper() + "/";
    #if !(USEPLGPATH)
            public static string LogFilePath = CFTools.AppDataPath + @"\Plugins\" + PluginName + @"\" + LogFile;
            public static string pConfigurationFile = CFTools.AppDataPath + @"\Plugins\" + PluginName + @"\" + ConfigurationFile;
    #else
            public static string LogFilePath = CFTools.StartupPath + @"\Plugins\" + PluginName + @"\" + LogFile;
            public static string pConfigurationFile = CFTools.StartupPath + @"\Plugins\" + PluginName + @"\" + ConfigurationFile;
    #endif
    		#endregion
            #region NOVOPARK
            #endregion NOVOPARK
            #region VIDEO CAPTURING
            public void ChangePreviewState(bool showVideo)
                int hr = 0;
                // If the media control interface isn't ready, don't call it
                if (this.mediaControl == null) CaptureVideo();
                if (showVideo)
                    if (this.currentState != PlayState.Running)
                        // Start previewing video data
                        hr = this.mediaControl.Run();
                        this.currentState = PlayState.Running;
                        WriteLog("ChangePreviewState:PlayState = RUNNING");
                else
                    // Stop previewing video data
                    hr = this.mediaControl.StopWhenReady();
                    this.currentState = PlayState.Stopped;
                    WriteLog("ChangePreviewState:PlayState = STOPPED");
            public void HandleGraphEvent()
                int hr = 0;
                EventCode evCode;
                IntPtr evParam1, evParam2;
                if (this.mediaEventEx == null) return;
                while (this.mediaEventEx.GetEvent(out evCode, out evParam1, out evParam2, 0) == 0)
                    // Free event parameters to prevent memory leaks associated with
                    // event parameter data.  While this application is not interested
                    // in the received events, applications should always process them.
                    hr = this.mediaEventEx.FreeEventParams(evCode, evParam1, evParam2);
                    DsError.ThrowExceptionForHR(hr);
                    // Insert event processing code here, if desired
            public void ResizeVideoWindow()
                // Resize the video preview window to match owner window size
                if (this.videoWindow != null)
                    string[] videodimensions = new string[4];
                    try
                    if (bFullScreen == false)
                        videodimensions = pluginSkinReader.GetControlAttribute("PDC", "VIDEOFRAME", "bounds").Split(';');
                        #region REDUCED VIDEOCREEN
                        this.videoWindow.SetWindowPosition(
                            (int)(Int32.Parse(videodimensions[0]) * pluginSkinReader.skinWidthRatio),
                            (int)(Int32.Parse(videodimensions[1]) * pluginSkinReader.skinHeightRatio),
                            (int)(Int32.Parse(videodimensions[2]) * pluginSkinReader.skinWidthRatio),
                            (int)(Int32.Parse(videodimensions[3]) * pluginSkinReader.skinHeightRatio)
                        #endregion
                    else
                        videodimensions = pluginSkinReader.GetControlAttribute("PDC", "VIDEOFRAMEFULL", "bounds").Split(';');
                        #region FULLSCREEN
                        #endregion
                    catch (Exception ex) { WriteLog(ex.ToString()); }
            public void SetupVideoWindow()
                int hr = 0;
                // Set the video window to be a child of the main window
                hr = this.videoWindow.put_Owner(this.Handle);
                hr = this.videoWindow.put_WindowStyle(WindowStyle.Child | WindowStyle.ClipChildren);
                // Use helper function to position video window in client rect
                // of main application window
                ResizeVideoWindow();
                // Make the video window visible, now that it is properly positioned
                hr = this.videoWindow.put_Visible(OABool.True);
            public void CloseInterfaces()
                // Stop previewing data
                if (this.mediaControl != null)
                // Stop receiving events
                if (this.mediaEventEx != null)
                    this.mediaEventEx.SetNotifyWindow(IntPtr.Zero, WM_GRAPHNOTIFY, IntPtr.Zero);
                // Relinquish ownership (IMPORTANT!) of the video window.
                // Failing to call put_Owner can lead to assert failures within
                // the video renderer, as it still assumes that it has a valid
                // parent window.
                    this.videoWindow.put_Visible(OABool.False);
                    this.videoWindow.put_Owner(IntPtr.Zero);
                // Remove filter graph from the running object table
                if (rot != null)
                    rot.Dispose();
                    rot = null;
                // Release DirectShow interfaces
                    Marshal.ReleaseComObject(this.mediaControl); this.mediaControl = null;
                    Marshal.ReleaseComObject(this.mediaEventEx); this.mediaEventEx = null;
                    Marshal.ReleaseComObject(this.videoWindow); this.videoWindow = null;
                    Marshal.ReleaseComObject(this.graphBuilder); this.graphBuilder = null;
                    Marshal.ReleaseComObject(this.captureGraphBuilder); this.captureGraphBuilder = null;
            public void GetInterfaces()
                int hr = 0;
                // An exception is thrown if cast fail
                this.graphBuilder = (IGraphBuilder)new FilterGraph();
                this.captureGraphBuilder = (ICaptureGraphBuilder2)new CaptureGraphBuilder2();
                this.mediaControl = (IMediaControl)this.graphBuilder;
                this.videoWindow = (IVideoWindow)this.graphBuilder;
                this.mediaEventEx = (IMediaEventEx)this.graphBuilder;
                hr = this.mediaEventEx.SetNotifyWindow(this.Handle, WM_GRAPHNOTIFY, IntPtr.Zero);
            private IBaseFilter CreateFilter(Guid category, string friendlyname)
                object source = null;
                Guid iid = typeof(IBaseFilter).GUID;
                foreach (DsDevice device in DsDevice.GetDevicesOfCat(category))
                    if (device.Name.CompareTo(friendlyname) == 0)
                        device.Mon.BindToObject(null, null, ref iid, out source);
                        break;
                return (IBaseFilter)source;
            public void CaptureVideo()
                int hr = 0;
                IBaseFilter sourceFilter = null;
                try
                    // Get DirectShow interfaces
                    GetInterfaces();
                    // Attach the filter graph to the capture graph
                    hr = this.captureGraphBuilder.SetFiltergraph(this.graphBuilder);
                    WriteLog("CaptureVideo:[Error code] captureGraphBuilder.SetFiltergraph: " + DsError.GetErrorText(hr));
                    // Use the system device enumerator and class enumerator to find
                    // a video capture/preview device, such as a desktop USB video camera.
                    string devicepath = this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/VIDEODEVICE");
                    WriteLog("CaptureVideo: Devicepath = " + devicepath);
                    try
                        pdc.VideoDevice = CreateFilter(FilterCategory.VideoInputDevice, devicepath);
                        sourceFilter = pdc.VideoDevice;
                        // Add Capture filter to our graph.
                        hr = this.graphBuilder.AddFilter(sourceFilter, "PDC");
                        WriteLog("CaptureVideo:[Error code] Addfilter: " + DsError.GetErrorText(hr));
                        // Render the preview pin on the video capture filter
                        // Use this instead of this.graphBuilder.RenderFile
                        hr = this.captureGraphBuilder.RenderStream(PinCategory.Preview, MediaType.Video, sourceFilter, null, null);
                        WriteLog("CaptureVideo:[Error code] RenderStream: " + DsError.GetErrorText(hr));
                        // Now that the filter has been added to the graph and we have
                        // rendered its stream, we can release this reference to the filter.
                        WriteLog("CaptureVideo: BEFORE ReleaseObject");
                        Marshal.ReleaseComObject(sourceFilter);
                        WriteLog("CaptureVideo: AFTER ReleaseObject");
                        // Set video window style and position
                        WriteLog("CaptureVideo: BEFORE SetupVideoWindow");
                        SetupVideoWindow();
                        WriteLog("CaptureVideo: AFTER SetupVideoWindow");
                        // Add our graph to the running object table, which will allow
                        // the GraphEdit application to "spy" on our graph
                        WriteLog("CaptureVideo: BEFORE DsROTEntry");
                        rot = new DsROTEntry(this.graphBuilder);
                        WriteLog("CaptureVideo: AFTER DsROTEntry");
                        WriteLog("CaptureVideo:[Error code] mediaControl.Run: " + DsError.GetErrorText(hr));
                        // Remember current state
                        WriteLog("CaptureVideo: sucessfully started");
                        WriteLog("CaptureVideo:[ERROR] CaptureVideo could not be started " + ex.ToString());
                catch (Exception errmsg) { CFTools.writeError(DsError.GetErrorText(hr), errmsg.StackTrace); }
            #endregion
            #region DISTANCE SYMBOL HANDLING
            public bool STOP_AUDIO
                get { return bAUDIO_STOP;  }
                set
                    bAUDIO_STOP = value;
                    if (bAUDIO_STOP == true)
                        if (ENABLE_AUDIO_STOP) this.CF_systemCommand(CF_Actions.MUTEAUDIO);
                    else
                        this.CF_systemCommand(CF_Actions.UNMUTEAUDIO);
            internal byte GetSliderNumber(ref byte dist)
                // Default (No Action)
                byte sldnr;
                if (dist >= 200) sldnr = 20;
                else             sldnr = Convert.ToByte(Math.Round((Convert.ToDecimal(dist) / 11), 0));
                if (sldnr < 0)   sldnr = 20;
                return sldnr;
            public string DistanceToString(ref byte Distance)
                string retStr = string.Empty;
                double d = Distance;
                if (Distance > 200)
                    retStr = "----" + DistanceSuffix;
                else
                   switch (DistanceUnit)
                        case Unit.meters:
                            retStr = String.Format("{0:F2} ", d /100) + DistanceSuffix;
                            break;
                        case Unit.inches:
                            retStr = String.Format("{0:F1} ", d / 2.54) + DistanceSuffix;
                            break;
                        case Unit.feet:
                            retStr = String.Format("{0:F2} ", d / 30.48) + DistanceSuffix;
                            break;
                return retStr;
            #if SIMULATION
            // ONLY FOR SIMULATION PURPOSES
            protected void SliderTimer_Tick(object sender, EventArgs e)
                byte rf = GetSliderNumber(ref SIMULATION_DISTANCE);
                //string BASEFOLDER = Application.StartupPath + @"\" + pluginFolder + @"\skins\" + this.currentSkin;
                SIMULATION_DISTANCE--;
                if (SIMULATION_DISTANCE <= 0) SIMULATION_DISTANCE = 254;
                try
                    SliderTimer.Stop();
                    if (this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTFRONT").ToUpper() == "TRUE")
                        if (this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/ENABLECAM").ToUpper() == "TRUE")
                            // front distance sensors
                            SetBlockImages(rf, rf, rf, rf, true, true);
                            this.CF_updateText("DISTANCE_FRONT", DistanceToString(ref SIMULATION_DISTANCE));
                        else
                            SetBlockImages(rf, rf, rf, rf, false, true);
                            this.CF_updateText("DISTANCE_FRONT_NC", DistanceToString(ref SIMULATION_DISTANCE));
                    if (this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTREAR").ToUpper() == "TRUE")
                            SetBlockImages(rf, rf, rf, rf, true, false);
                            this.CF_updateText("DISTANCE_REAR", DistanceToString(ref SIMULATION_DISTANCE));
                        else
                            SetBlockImages(rf, rf, rf, rf, false, false);
                            this.CF_updateText("DISTANCE_REAR_NC", DistanceToString(ref SIMULATION_DISTANCE));
                catch (Exception errmsg) { CFTools.writeError(errmsg.Message, errmsg.StackTrace); }
                SliderTimer.Start();
            #endif
            #endregion
            public static string LimitLength (string input, int maxLength)
                string d = string.Empty;
                if (input.Length > maxLength)
    				int cBegin, cEnd;
    				string sMiddle = "...";
    				cBegin = (int)System.Math.Floor(0.5 * maxLength);
    				cEnd = maxLength - cBegin - sMiddle.Length;
    				d = input.Substring(0, cBegin) + sMiddle + input.Substring(input.Length - cEnd, cEnd);
    			else
    				d = input;
                return d;
            public override string CF_pluginDefaultConfig()
               string temp = "<APPCONFIG>\r\n" +
                             "    <VERSION>" + Assembly.GetExecutingAssembly().GetName().Version.ToString() + "</VERSION>\r\n" +
                             "    <SETTINGS>\r\n" +
                             "      <DEVICEFRONT>NONE</DEVICEFRONT>\r\n" +
                             "      <DEVICEREAR>NONE</DEVICEREAR>\r\n" +
                             "      <MAINVOLLEVEL>100</MAINVOLLEVEL>\r\n" +
                             "      <USEDEBUG>FALSE</USEDEBUG>\r\n" +
                             "      <DEBUGTOERRORFILE>TRUE</DEBUGTOERRORFILE>\r\n" +
                             "      <DETECTFRONT>FALSE</DETECTFRONT>\r\n" +
                             "      <DETECTREAR>FALSE</DETECTREAR>\r\n" +
                             "      <PAUSEAUDIO>TRUE</PAUSEAUDIO>\r\n" +
                             "      <USEHARDWAREBEEP>FALSE</USEHARDWAREBEEP>\r\n" +
                             "      <ENABLECAM>FALSE</ENABLECAM>\r\n" +
                             "      <VIDEODEVICE>NONE</VIDEODEVICE>\r\n" +
                             "      <DIMENSION>m</DIMENSION>\r\n" +
                             "      <INTERVALLMS>500</INTERVALLMS>\r\n" +
                             "      <HIDETIMEMS>2000</HIDETIMEMS>\r\n" +
                             "      <DISTSHOWREAR>0</DISTSHOWREAR>\r\n" +
                             "      <DISTSHOWFRONT>0</DISTSHOWFRONT>\r\n" +
                             "      <USEVERTICAL>FALSE</USEVERTICAL>\r\n" +
                             "      <HOLDOPENTIME>15</HOLDOPENTIME>\r\n" +
                             "    </SETTINGS>\r\n" +
                             "</APPCONFIG>\r\n";
               return temp;
            private void AddConfigXml()
                WriteLog("AddConfigXml:Start");
                try
    #if !(USEPLGPATH)
                    // Create applicationdata folder if doesn't exist
                    if (!Directory.Exists(CFTools.AppDataPath + "\\Plugins\\" + PluginName))
                        Directory.CreateDirectory(CFTools.AppDataPath + "\\Plugins\\" + PluginName);
    #endif
                    // Create config.xml file if doesn't exist
                    WriteLog("AddConfigXml: Search config file <" + pConfigurationFile + ">");
                    if (!File.Exists(pConfigurationFile))
                        // quick creation of new file
                        FileStream fs = new FileStream(pConfigurationFile, FileMode.Create, FileAccess.Write, FileShare.Write);
                        fs.Close();
                        // now insert data to new file
                        StreamWriter sw = new StreamWriter(pConfigurationFile, false, System.Text.Encoding.ASCII);
                        sw.Write(CF_pluginDefaultConfig());
                        sw.Close();
                        WriteLog("AddConfigXml: New config.xml file created!");
                WriteLog("AddConfigXml:Stop");
                return;
            public static void WriteLog(string msg)
                try
                    if (useDebug)
                        if (useErrorOutput)
                            CFTools.writeError(PluginName + ":" + msg);
                        else
                            CFTools.writeModuleLog(PluginName + ":" + msg, LogFilePath);
                catch { }
            #region CFPlugin methods
            public pdc()
                this.CF_params.pauseAudio = false;
                this.CF_params.pluginName = PluginName.ToUpper();
                this.CF_params.isGUI = true;
                this.CF_params.hasSettings = true;
                this.CF_params.hasBasicSettings = true;
            public override void CF_pluginInit()
                try
                    this.CF3_initPlugin(PluginName.ToUpper(), true);
                    useDebug = Boolean.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/USEDEBUG"));
                    useErrorOutput = Boolean.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DEBUGTOERRORFILE"));
                    WriteLog("PDC:Startup");
                    WriteLog("CF_pluginInit:Start");
                    checkTimer = new System.Windows.Forms.Timer();
                    HoldOpenTimer = new System.Windows.Forms.Timer();
                    this.CF_localskinsetup();
                    #region SET DEFAULT VALUES
                    // Actions that must execute when the program starts.
    #if SIMULATION
    				SliderTimer = new System.Windows.Forms.Timer();
                    SliderTimer.Tick += new EventHandler(SliderTimer_Tick);
                    SliderTimer.Interval = 50;
    #endif
                    #endregion
                    checkTimer.Tick += new EventHandler(checkTimer_Tick);
                    HoldOpenTimer.Tick += new EventHandler(HoldOpenTimer_Tick);
                    HookHardwareNotifications(this.Handle, false);
    #if SIMULATION
    #endif
                    LoadSettings();
                finally
                    // create event to detect application is loaded and powermode changed
                    this.CF_events.applicationLoaded += new EventHandler(PDC_Loaded);
                    this.CF_events.powerModeChanged += new Microsoft.Win32.PowerModeChangedEventHandler(PDC_CF_Event_powerModeChanged);
                pa_init();
                pa_ping();
            public override void CF_pluginShow()
                OpenScreen();
    		public override void CF_pluginClose()
                #if SIMULATION
                SliderTimer.Stop();
                #endif
                this.CF_events.powerModeChanged -= new Microsoft.Win32.PowerModeChangedEventHandler(PDC_CF_Event_powerModeChanged);
                CloseInterfaces();
                this.Dispose();
            public override DialogResult CF_pluginShowSetup()
                WriteLog("CF_pluginShowSetup:Start");
                // This is called by the system when the plugin setup is clicked.
                // Return DialogResult.OK for the main application to update from plugin changes.
                DialogResult returnvalue = DialogResult.Cancel;
                try
                    // Creates a new plugin setup instance. If you create a CFDialog or CFSetup you must set
                    // its MainForm property to the main plugins MainForm property.
                    setup Setup = new setup(this.MainForm, this.pluginConfig, this.pluginLang);
                    returnvalue = Setup.ShowDialog();
                    if (returnvalue == DialogResult.OK)
                        // Reloads plugin configuration.
                        this.pluginConfig.Reload();
                        LoadSettings();
                    Setup.Close();
                    Setup = null;
                WriteLog("CF_pluginShowSetup:Stop");
                return returnvalue;
    		public override void CF_pluginPause()
    			// This is called by the system when it pauses all audio.
    		public override void CF_pluginResume()
    			// This is called by the system when it resumes all audio.
    		public override void CF_pluginCommand(string command, string param1, string param2)
    			// Used for plugin to plugin communication.  Parameters can be passed into CF_Main_systemCommands
    			// with CF_Actions.PLUGIN, plugin name, plugin command, and a command parameter.
    		public override string CF_pluginData(string command, string param)
    			// Used for retrieving information from plugins. You can run CF_getPluginData with a plugin name,
    			// command, and parameter to retrieve information from other plugins running on the system.
    			return "";
            public void LoadSettings()
                WriteLog("LoadSettings:Start");
    			if (Assembly.GetExecutingAssembly().GetName().Version.ToString().CompareTo(this.pluginConfig.ReadField("/APPCONFIG/VERSION")) != 0)
    				this.pluginConfig.WriteField("/APPCONFIG/VERSION", Assembly.GetExecutingAssembly().GetName().Version.ToString());
                    this.pluginConfig.Save();
                try { useDebug = Boolean.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/USEDEBUG")); }
    			catch {useDebug = false;}
                try { GHoldOpenTime = int.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/HOLDOPENTIME")) * 1000; }
                catch { GHoldOpenTime = 5000; }
                try
                    switch (this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DIMENSION"))
                        case "m":
                            DistanceUnit = Unit.meters;
                            DistanceSuffix = " " + this.pluginLang.ReadField("/APPLANG/PDC/DIMENSION/METER").Split(';')[1];
                            break;
                        case "ft":
                            DistanceUnit = Unit.feet;
                            DistanceSuffix = " " + this.pluginLang.ReadField("/APPLANG/PDC/DIMENSION/FEED").Split(';')[1];
                            break;
                        case "inch":
                            DistanceUnit = Unit.inches;
                            DistanceSuffix = " " + this.pluginLang.ReadField("/APPLANG/PDC/DIMENSION/INCH").Split(';')[1];
                            break;
                catch { DistanceSuffix = " m"; DistanceUnit = Unit.meters; }
                try
                    ENABLE_AUDIO_STOP = bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/PAUSEAUDIO"));
                // The display name is shown in the application to represent
                // the plugin.  This sets the display name from the configuration file.
                this.CF_params.displayName = TranslateText("DISPLAYNAME");
                WriteLog("LoadSettings:Stop");
            private string TranslateText(string text)
                string langread = this.pluginLang.ReadField(LanguageSection + text);
                if (langread == "")
                    return text;
                else
                    return langread.Replace("\\n", "\n");
            protected override void WndProc(ref Message m)
                switch (m.Msg)
                    case WM_GRAPHNOTIFY:
                            HandleGraphEvent();
                            break;
                    case Win32Usb.WM_DEVICECHANGE:
                           WriteLog("WndProc:ReceiverDevice_OnDeviceChanged");
                           checkTimer.Enabled = true;
                           break;
                // Pass this message to the video window for notification of system changes
                    this.videoWindow.NotifyOwnerMessage(m.HWnd, m.Msg, m.WParam, m.LParam);
                base.WndProc(ref m);
            public bool HookHardwareNotifications(IntPtr callback, bool UseWindowHandle)
                try
                    Win32Usb.DeviceBroadcastInterface dbdi = new Win32Usb.DeviceBroadcastInterface();
                    dbdi.Size = Marshal.SizeOf(dbdi);
                    dbdi.Reserved = 0;
                    dbdi.DeviceType = Win32Usb.DBT_DEVTYP_DEVICEINTERFACE;
                    if (UseWindowHandle)
                        Win32Usb.RegisterDeviceNotification(callback,
                            dbdi,
                            Win32Usb.DEVICE_NOTIFY_ALL_INTERFACE_CLASSES |
                            Win32Usb.DEVICE_NOTIFY_WINDOW_HANDLE);
                    else
                            dbdi,
                            Win32Usb.DEVICE_NOTIFY_SERVICE_HANDLE);
                    return true;
                    string err = ex.Message;
                    return false;
            public override void CF_localskinsetup()
    			///  This is called to setup the skin.  This will usually be called  in CF_pluginInit.
    			///  It will also called by the system when the resolution has been changed.
                WriteLog("CF_localskinsetup:Start");
                try
                    if (Directory.Exists(this.CF_params.pluginSkinPath + @"\FRONT_A"))
                        GLOBAL_SLIDER_PATH = this.CF_params.pluginSkinPath;
                    else
                        GLOBAL_SLIDER_PATH = CFTools.StartupPath + @"\" + PluginPath + @"Slider";
                catch (Exception errmsg) { CFTools.writeError("Error in finding slider path", errmsg.Message); }
                try
                    bFullScreen = ((this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTFRONT").ToUpper() == "FALSE") &
                       (this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTREAR").ToUpper() == "FALSE"));
                    #region load two possible skins with camera section
                            CF3_initSection("PDC");
    	                    if (bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTFRONT")) == true)
                                this.CF3_createPictureBox("FRONT_A");
                                this.CF3_createPictureBox("FRONT_B");
                                this.CF3_createPictureBox("FRONT_C");
                                this.CF3_createPictureBox("FRONT_D");
                                SetBlockImages(20, 20, 20, 20, true, true);
                                this.CF3_createLabel("DISTANCE_FRONT");
                                this.CF_updateText("DISTANCE_FRONT", "-,-- m");
                            if (bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTREAR")) == true)
                                // rear distance sensors
                                this.CF3_createPictureBox("REAR_A");
                                this.CF3_createPictureBox("REAR_B");
                                this.CF3_createPictureBox("REAR_C");
                                this.CF3_createPictureBox("REAR_D");
                                SetBlockImages(20, 20, 20, 20, true, false);
                                this.CF3_createLabel("DISTANCE_REAR");
                                this.CF_updateText("DISTANCE_REAR", "-,-- m");
                            // car symbol/image
                            string[] carbounds = new string[4];
                            carbounds = pluginSkinReader.GetControlAttribute("PDC", "CAR", "bounds").Split(';');
                            string filetype = "gif";
                            if (File.Exists(this.CF_params.pluginSkinPath + @"\car.png")) { filetype = "png"; }
                            Image car = Image.FromFile(this.CF_params.pluginSkinPath + @"\car." + filetype);
                            Image resized = car.GetThumbnailImage(Int32.Parse(carbounds[2]), Int32.Parse(carbounds[3]), null, IntPtr.Zero);
                            this.CF_setPictureImage("CAR", resized);
                            this.CF_updateText("TITLE", this.pluginLang.ReadField("/APPLANG/PDC/TITLE"));
                            this.CF_updateText("VERSION", this.pluginLang.ReadField("APPLANG/PDC/VERSIONNAME") + Assembly.GetExecutingAssembly().GetName().Version.ToString());
                        else
                            CF3_initSection("PDC_FULL");
                        CaptureVideo();
                    else
                        CF3_initSection("PDC_NC");
                        if (pdc.VideoDevice != null) CloseInterfaces();
                            this.CF3_createPictureBox("FRONT_A_NC");
                            this.CF3_createPictureBox("FRONT_B_NC");
                            this.CF3_createPictureBox("FRONT_C_NC");
                            this.CF3_createPictureBox("FRONT_D_NC");
                            SetBlockImages(20, 20, 20, 20, false, true);
                            this.CF3_createLabel("DISTANCE_FRONT_NC");
                            this.CF_updateText("DISTANCE_FRONT_NC", "-,-- m");
                            this.CF3_createPictureBox("REAR_A_NC");
                            this.CF3_createPictureBox("REAR_B_NC");
                            this.CF3_createPictureBox("REAR_C_NC");
                            this.CF3_createPictureBox("REAR_D_NC");
                            SetBlockImages(20, 20, 20, 20, false, false);
                            this.CF3_createLabel("DISTANCE_REAR_NC");
                            this.CF_updateText("DISTANCE_REAR_NC", "-,-- m");
                        this.CF_updateText("TITLE_NC", this.pluginLang.ReadField("/APPLANG/PDC/TITLE"));
                        this.CF_updateText("VERSION_NC", this.pluginLang.ReadField("APPLANG/PDC/VERSIONNAME") + Assembly.GetExecutingAssembly().GetName().Version.ToString());
                        // car symbol/image
                        this.CF_setPictureImage("CAR_NC", Image.FromFile(this.CF_params.pluginSkinPath + @"\car.gif"));
                    #endregion
                WriteLog("CF_localskinsetup:Stop");
    		#endregion
            public void ShowLargeMessage(string txt)
    			try
                    message Msg = new message(this.MainForm, this.pluginConfig, this.pluginLang);
    				Msg.MESSAGETEXT = txt;
    				Msg.CF_pluginInit();
    				returnvalue = Msg.ShowDialog();
    				Msg.Close();
    				Msg = null;
    			catch(Exception errmsg) { CFTools.writeError(errmsg.Message, errmsg.StackTrace); }
            protected void checkTimer_Tick(object sender, EventArgs e)
    		    checkTimer.Stop();
                if (this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTREAR").ToUpper() == "TRUE") GetDataFromDeviceRear();
                if (this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/DETECTFRONT").ToUpper() == "TRUE") GetDataFromDeviceFront();
                // Restart the checktimer only if one or both detectors are present
                // TODO: Consider device is presented for sake of experiment
                checkTimer.Start();
            protected void HoldOpenTimer_Tick(object sender, EventArgs e)
                HoldOpenTimer.Stop();
                bCLOSEABLE = true;
            private void NoUsb()
                        this.CF_setPictureImage("CAR", Image.FromFile(this.CF_params.pluginSkinPath + @"\NoUsb.png"));
                            SetBlockImages(21, 21, 21, 21, true, true);
                            this.CF_updateText("DISTANCE_FRONT", "-,-- " + DistanceSuffix);
                            SetBlockImages(21, 21, 21, 21, true, false);
                            this.CF_updateText("DISTANCE_REAR", "-,-- " + DistanceSuffix);
                else
                    this.CF_setPictureImage("CAR_NC", Image.FromFile(this.CF_params.pluginSkinPath + @"\NoUsb.png"));
                        SetBlockImages(21, 21, 21, 21, false, true);
                        this.CF_updateText("DISTANCE_FRONT_NC", "-,-- " + DistanceSuffix);
                        SetBlockImages(21, 21, 21, 21, false, false);
                        this.CF_updateText("DISTANCE_REAR_NC", "-,-- " + DistanceSuffix);
            // Main section to retrieve data from USB PDC device
            private void CloseScreen()
                if (bCLOSEABLE == true)
                    this.Visible = false;
            private void OpenScreen()
                this.Visible = true;
                bCLOSEABLE = false;
                HoldOpenTimer.Interval = GHoldOpenTime;
                HoldOpenTimer.Start();
            private void GetDataFromDeviceRear()
                //Sends one byte to the device and reads five bytes back.
                byte mDist;
                byte mRef=0xFF;
                // If the device hasn't been detected or it timed out on a previous attempt
                // to access it, look for the device. (currently only rear device)
                try
                    #region deviceRear was found
                    // The device has been detected, now load the buffer with the byte to be sent
                    // Get distances
                    pa_poll();
                    for (int s = 4; s <= 7; s++)
                        if (pa_head_visible(s) == 1)
                            Sensor[s].Distance = (byte)pa_head_distance(s);
                        else
                            Sensor[s].Distance = 255;
                    // Get the minimum distance detected from the sensors
                    mDist = 0xff;
                        if (Sensor[s].Distance < mDist)
                            mDist = Sensor[s].Distance;
                    if (mDist < mRef)
                        #region 'DISTANCE <= REFERENCE DISTANCE'
                        // show the plugin main skin ....
                        OpenScreen();
                        STOP_AUDIO = true;
                        // now set the timer to a shorter intervall
                        checkTimer.Interval = pa_poll_interval();
                        // set the audio volume lowering value
                        if (bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/PAUSEAUDIO")) == true) SetReducedAudio();
                        // Quick display update
                        if (bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/ENABLECAM")) == true)
                            #region SHOW VIDEO FRAME
                            ChangePreviewState(true);
                            this.CF_updateText("DISTANCE_REAR", DistanceToString(ref mDist));
                            // update the distance blocks
                            SetBlockImages(GetSliderNumber(ref Sensor[7].Distance),
                                            GetSliderNumber(ref Sensor[6].Distance),
                                            GetSliderNumber(ref Sensor[5].Distance),
                                            GetSliderNumber(ref Sensor[4].Distance),
                                            true, false);
                            #endregion SHOW VIDEO FRAME
                        else
                            #region DONT SHOW VIDEO FRAME
                            ChangePreviewState(false);
                            this.CF_updateText("DISTANCE_REAR_NC", DistanceToString(ref mDist));
                            // update the distance blocks without camera
                                            false, false);
                            #endregion DONT SHOW VIDEO FRAME
                        #endregion 'DISTANCE <= REFERENCE DISTANCE'
                    else
                        #region 'DISTANCE > REFERENCE DISTANCE'
                        // now set the timer to a longer intervall
                        checkTimer.Interval = 1000;
                        // If need, restart the audio player
                        STOP_AUDIO = false;
                            SetNormalAudio();
                        else
                        if (mRef != 0) CloseScreen();
                        #endregion 'DISTANCE > REFERENCE DISTANCE'
                    #endregion deviceRear was found
                catch { }
            private void SetNormalAudio()
                if (VolumeLevel.IsReduced == true)
                    this.CF_setMixerLevel((int)CF_MixerDevices.MAIN, 0, (int)VolumeLevel.LastVolume, false);
                    VolumeLevel.IsReduced = false;
            private void SetReducedAudio()
                float iRedLevel = 0;
                if (VolumeLevel.IsReduced != true)
                    VolumeLevel.IsReduced = true;
                    VolumeLevel.LastVolume = this.CF_getMixerLevel((int)CF_MixerDevices.MAIN, 0, false);
                    try
                        float.TryParse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/MAINVOLLEVEL"), out iRedLevel);
                        if (iRedLevel > 0)
                            iRedLevel = VolumeLevel.LastVolume * iRedLevel / 100;
                    catch { }
                    this.CF_setMixerLevel((int)CF_MixerDevices.MAIN, 0, (int)iRedLevel, false);
            private void GetDataFromDeviceFront()
                byte mDist;
                byte mRef=0xff;
                try
                    #region deviceFront was found
                    // Get distances
                    pa_poll();
                    for (int s = 0; s <= 3; s++)
                        else
                    mDist = 0xff;
                        if (Sensor[s].Distance < mDist) mDist = Sensor[s].Distance;
                    #region distance detection started...
                    if (mDist < mRef)
                        OpenScreen();
                        STOP_AUDIO = true;
                        checkTimer.Interval = 250;
                        if (bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/PAUSEAUDIO"))==true) SetReducedAudio();
                        // If need, set the main volume
                            this.CF_updateText("DISTANCE_FRONT", DistanceToString(ref mDist));
                            SetBlockImages(GetSliderNumber(ref Sensor[3].Distance),
                                            GetSliderNumber(ref Sensor[2].Distance),
                                            GetSliderNumber(ref Sensor[1].Distance),
                                            GetSliderNumber(ref Sensor[0].Distance),
                                            true, true);
                        else
                            this.CF_updateText("DISTANCE_FRONT_NC", DistanceToString(ref mDist));
                                            false, true);
                    #endregion
                    else
                        STOP_AUDIO = false;
                        if (bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/PAUSEAUDIO")) == true) SetNormalAudio();
                        else
                    #endregion deviceFront was found
                catch { }
            private void SetBlockImages(byte vA, byte vB, byte vC, byte vD, bool useCam, bool IsFront)
                if (IsFront == false)
                    if (useCam == true)
                        // display value with camera
                        this.CF_setPictureImage("REAR_A", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_A\SLIDERH_" + Convert.ToString(vA) + ".gif"));
                        this.CF_setPictureImage("REAR_B", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_B\SLIDERH_" + Convert.ToString(vB) + ".gif"));
                        this.CF_setPictureImage("REAR_C", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_C\SLIDERH_" + Convert.ToString(vC) + ".gif"));
                        this.CF_setPictureImage("REAR_D", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_D\SLIDERH_" + Convert.ToString(vD) + ".gif"));
                    else
                        // display value without camera
                        this.CF_setPictureImage("REAR_A_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_A\SLIDERH_" + Convert.ToString(vA) + ".gif"));
                        this.CF_setPictureImage("REAR_B_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_B\SLIDERH_" + Convert.ToString(vB) + ".gif"));
                        this.CF_setPictureImage("REAR_C_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_C\SLIDERH_" + Convert.ToString(vC) + ".gif"));
                        this.CF_setPictureImage("REAR_D_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\REAR_D\SLIDERH_" + Convert.ToString(vD) + ".gif"));
                else
                    if (useCam == true)
                        this.CF_setPictureImage("FRONT_A", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_A\SLIDERH_" + Convert.ToString(vA) + ".gif"));
                        this.CF_setPictureImage("FRONT_B", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_B\SLIDERH_" + Convert.ToString(vB) + ".gif"));
                        this.CF_setPictureImage("FRONT_C", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_C\SLIDERH_" + Convert.ToString(vC) + ".gif"));
                        this.CF_setPictureImage("FRONT_D", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_D\SLIDERH_" + Convert.ToString(vD) + ".gif"));
                    else
                        this.CF_setPictureImage("FRONT_A_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_A\SLIDERH_" + Convert.ToString(vA) + ".gif"));
                        this.CF_setPictureImage("FRONT_B_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_B\SLIDERH_" + Convert.ToString(vB) + ".gif"));
                        this.CF_setPictureImage("FRONT_C_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_C\SLIDERH_" + Convert.ToString(vC) + ".gif"));
                        this.CF_setPictureImage("FRONT_D_NC", Image.FromFile(GLOBAL_SLIDER_PATH + @"\FRONT_D\SLIDERH_" + Convert.ToString(vD) + ".gif"));
            private void PDC_Loaded(object sender, EventArgs e)
    			// Event that fires when the aplication is loaded.
                WriteLog("PDC_Loaded:Start");
                // checkTimer: Timer for detecting the distance to the next obtacle
    			try
                    checkTimer.Interval = pa_retry_delay();
                catch
                    // standard value = 5 seconds
                    if(checkTimer!=null) checkTimer.Interval = 5000;
                // HoldOpenTimer: Timer for holding plugin dialog open for n seconds
                try
                    HoldOpenTimer.Interval = pa_hide_delay();
                catch
                    if(HoldOpenTimer!=null) HoldOpenTimer.Interval = 5000;
                // Now search for the PDC USB receiver device
                // TODO: open device here
                // It is necessary to start the check timer also if no device is found
                // to ensure that an inserted device could be detected
                if(checkTimer!=null) checkTimer.Enabled = true;
                WriteLog("PDC_Loaded:Stop");
            private void ReceiverDevice_OnDeviceArrived(object sender, EventArgs e)
                WriteLog("ReceiverDevice_OnDeviceArrived:Start");
                if (InvokeRequired)
                    Invoke(new EventHandler(ReceiverDevice_OnDeviceArrived), new object[] { sender, e });
                else
                    WriteLog("ReceiverDevice_OnDeviceArrived:ReceiverDevice_OnDeviceArrived");
                WriteLog("ReceiverDevice_OnDeviceArrived:Stop");
            private void SetValues2Zero()
                Sensor[0].OldFrontValue = 0;
                Sensor[1].OldFrontValue = 0;
                Sensor[2].OldFrontValue = 0;
                Sensor[3].OldFrontValue = 0;
                Sensor[0].OldRearValue = 0;
                Sensor[1].OldRearValue = 0;
                Sensor[2].OldRearValue = 0;
                Sensor[3].OldRearValue = 0;
            private void PDC_CF_Event_powerModeChanged(object sender, Microsoft.Win32.PowerModeChangedEventArgs e)
                if (e.Mode.ToString() == "Suspend")
                    WriteLog("PDC_CF_Event_powerModeChanged - Mode: Suspend");
                    checkTimer.Stop();
                    SetValues2Zero();
                    // NEW: 5.1.2009 - restart video capturing after RESUME
                        CloseInterfaces();
                else if (e.Mode.ToString() == "Resume")
                    WriteLog("PDC_CF_Event_powerModeChanged - Mode: Resume");
                    LoadSettings();
                    STOP_AUDIO = false;
                    if (bool.Parse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/ENABLECAM")) == true )
                        // wait 15 seconds before restart of camera usb device
                        // there are some devices which takes a little bit longer to restart.
                        int WaitingTime;
                        bool res = int.TryParse(this.pluginConfig.ReadField("/APPCONFIG/SETTINGS/USBDELAYSECONDS"), out WaitingTime);
                        if (res == false)
                            WaitingTime = 15000;
                        else
                            if ((WaitingTime > 0) && (WaitingTime < 60))
                                WaitingTime *= 1000;
                            else
                        while (WaitingTime > 0)
                            Application.DoEvents();
                            WaitingTime = WaitingTime - 100;
                            System.Threading.Thread.Sleep(100);
                        CaptureVideo();
                    // Restart PCD devices again if config parameter for a device is set to TRUE
                    // TODO: Opening device here
                    checkTimer.Start();
                    WriteLog("PDC_CF_Event_powerModeChanged:Stop");
    Will contract for C++/Win-Linux/PIC jobs
  2. #382
    Jul 2011
    Parking Sensors For Caravans
    Hi Guys just wanted to know if anyone could recommend a wireless parking sensor kit for a Swift Caravan.
    thanks
    Quote Originally Posted by mJrO View Post
    Hi everyone.
    I have a "no drill" or electromagnetic strip parking sensor.
    Will this interface work with it?
    Mine is a clone of the proxel unit (http://www.proxel.com/).
    Any input will be appreciated.
  3. #383
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Is there a version of this that can be bought? Im not good at soldering.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  4. #384
  5. #385
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    as Enforcer said I sell them. If you don't wan't solder things then FULL kit is for you. All is builded together and tested. All you must to do is holes in bumper, and connect together things(connectors)...
  6. #386
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Dejan,
    I have added a link to your site from thelinks page on mine. (mainly because I am fed up of haing to search on google for the URL everytime someone askes about the PDC or TPMS kits ;-))
  7. #387
    Jul 2007
    Miami
    Thanx guys. I remember when the TPMS came out I bought the kit and tried to do myself. Well that didnt go so well and I bricked it and ended up buying the complete kit from LOK. I think this time its better if I just go straight to the full kits. If I want front and rear, I have to buy 2?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  8. #388
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by HiJackZX1 View Post
    I have to buy 2?
    Yep.
    The only thing with that is, you have to make sure you get one rear and one front kit.
    And only one can work wirelessly, the other has to be wired.
  9. #389
    Jan 2012
    So those USB 8 sensor kits on the previous page won't work? I'm a bit confused by those 2 posts lol.
  10. #390
    Feb 2010
    Looking for and Android solution, anything on the horizon?
    With this http://www.sparkfun.com/products/10585 and USB HOST enabled tablet it might be possible to enable communication =)
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  5. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
