Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: What would mp3car like to make?
  1. #11
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    How about this? A bluetooth dongle that turns the PC on when you get near the vicinity, an unlocks the doors.
    Want to:
  2. #12
    Vendor - Qube colin's Avatar
    Dec 2006
    I have that same idea written down in a notebook and I was dying trying to figure out how to use RFID within a certain distance and always get the right action (open windows / put top down on a hot day) with only a card in your wallet or something.
    On second thought, that's a much better idea, I vote for that one since SO many people would want it. Im not even willing to start tackling that project because right now theres only a bunch of small projects that can possibly be used to make this, but theres no central one. Confused? I mean like, there's bluetooth / RFID readers that are independant, then there's antennas, then there's card reader/writers, then theres bluetooth hardware stuff, then theres the actual program. All of these separate cost a lot of cashola.
  3. #13
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Shreveport, LA
    Quote Originally Posted by NiSlo View Post
    A video switch?
    Two Inputs - VGA & Composite
    One Output - VGA
    Idea - It automatically switches to the composite input when composite becomes active and switches back to VGA when composite becomes inactive. This would be sweet, as an easy way to add a reversing camera to a setup. You could just put it inline with the VGA input from the PC so you don't have to worry about manuall changing inputs on the monitor.
    Search for "cheesebox" . It's a box that does just what you're saying except the auto-switch. I wired a relay that pushes the button when my backup lights go on. Works just as you desire.
    Good luck.
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
  4. #14
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by Punky View Post
    Without industries experience, but from the way it looks, this project might be to easy for something that would require me to spend 1 whole year on. Please correct me if i'm wrong.
    Ahhhhh, I see what you're after now. Yeah it would take a lot less than one year to build I would imagine...
    Quote Originally Posted by Zoltan View Post
    Good luck.
    Sweet, thanks for the heads up!
    I installed my carpc into my pet Kangaroo, mate.
  5. #15
    Oct 2006
    I'll definately look into the bluetooth key thing, but damn that thread is long, anyone has been following it please give me a recap.
    Hvac is definitely keeping in mind. Though, i'd like to ask how that would interract with our carpc? To be honest, i don't trust MS windows to control my HVAC cuz, even if its stable right now, its still crashes here and there. Hell i don't even trust PC hardware to do it, because in canada it gets below -40*C HD goes out and you got no heat control lol. IF i go with an embedded processors or such, then how much difference is it from today's automatic climate control?
    Myrus' idea sounds great, but I'm going to have to research on that before i say anything because it require a lot of component that are software engineer and related problems.
  6. #16
    Dec 2006
    From what I've read in that, which was a fair while ago, nobody got anywhere. There are a few premade systems using cell phones and all that jazz, but nobody actually went through with the idea of using a bluetooth or RF keychain thingy to do anything to their car. Most people don't have the electronics knowledge to program a microchip to detect something as advanced as Bluetooth or RF.
    It would interact through USB as an HID device or you could write your own drivers (unnecessary). You could wire up spare buttons to the microcontroller to serve as manual adjustments, have like 5 presets! You could make a really slim little faceplate and nobody would know it's there. If your computer crashes or wont start, the microcontroller is still waiting for input, so you could press a low-profile button to turn on the heat, or crank the AC depending on weather. The difference is that you have complete control over every aspect, you don't have to use the car's limited controls. If you wanted the blower on half power, you could do that. If you wanted certain vents open and other ones closed, you could do that. If you want some crazy temperature controls, you can do that. See my point?
  7. #17
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Not exactly carpc related, but just another idea to throw in...active noise cancelling.
    You could have a device which goes inline between the line in and the amp. This would allow all your music to go through, yet the device would also add an inverted stream of the road noise to be played through the amp. Sounds simple enough to invert a wave, but not sure if something like this can easily be designed.
  1. Replies: 4
    Last Post: 11-09-2007, 12:40 PM
  2. Replies: 16
    Last Post: 09-05-2007, 04:19 PM
  3. Parrot Bluetooth carkit for CarPC
    By m-ruiter in forum Road Runner
    Last Post: 05-08-2006, 06:40 AM
  4. Starting to make a Skin, need some help please
    By Slickrick2000 in forum Newbie
    Last Post: 03-10-2006, 09:46 AM
  5. False floor
    By i3igmind in forum Fabrication
    Last Post: 02-04-2006, 10:28 PM
