Results 1 to 10 of 17
Thread: What would mp3car like to make?
    Oct 2006
    I'm a long time member of mp3car, and this fall is my final year of electrical engineering. We must complete a 4th year electrical engineering project as the curriculum requirement. I did not like any of the topics provided, and i would like mp3car's input. Since i have no industry experience, i don't know whether a project would be way over my time limit, and knowledge. What i'm looking for is an idea that would benefit the carpc community and reasonable for a 4th year electrical engineering student to do. So throw them out, and see what i could do!
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Reverse engineer Alpine's AiNET interface...
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Oct 2006
    lol, that would probally raises some legal issues, and plus i'm not really making anything presentable.
    Vendor - Qube colin's Avatar
    Dec 2006
    AC Controls are usually a touchy subject... if you could get a CHEAP controller that could output for a servo and a couple vacuum solenoids... you'd have one hell of a presentation, one hell of a market, and one hell of a wallet when youre done.
    It can be done, and if nobody does it soon, Ill be making one. I just need cash for the stupid vacuum solenoids.
    EDIT: I know theres the AirCon or whatever it's called -- not what I meant. I mean something reasonably priced for hobbyists. You could do this for MUCH cheaper with a simple $9 PIC and a motor driver chip... I can't see it costing more than 15 bucks for prototyping (not including the acutal hardware such as the solenoids / servos, but including things like temperature sensors and USB ports).
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    A video switch?
    Two Inputs - VGA & Composite
    One Output - VGA
    Idea - It automatically switches to the composite input when composite becomes active and switches back to VGA when composite becomes inactive. This would be sweet, as an easy way to add a reversing camera to a setup. You could just put it inline with the VGA input from the PC so you don't have to worry about manuall changing inputs on the monitor.
    I installed my carpc into my pet Kangaroo, mate.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I thought you just finished 3rd yr...I guess your not doing internship next semester?
    Why not present the whole carpc as your project? A carpc can do now what automakers are trying to achieve in the future. You can integrate it to your home network, phone, internet/email, check weather & traffic, voice recognition, etc... Maybe some sort of surveillance/dashcam, that would be really useful considering all the theft &vandalism that's going around town.
    Oct 2006
    Quote Originally Posted by colin View Post
    I'm a bit confused on what exactly you're describing, excuse my ignorance when it comes to HVAC systems. Is what you're asking me to do is create a controller that control every car's HVAC system? Because every car is different and some are just manual switches, and others are automatic. Unless you're talking about totally replacing the car's original HVAC and replace it with a whole new motor, and whatnot. Please expand, i'm somewhat interested in the idea.
    Quote Originally Posted by NiSlo View Post
    A video switch?
    One Output - VGA
    Without industries experience, but from the way it looks, this project might be to easy for something that would require me to spend 1 whole year on. Please correct me if i'm wrong.
    Quote Originally Posted by nobb View Post
    Sicked of school, i wanna finish asap, so no intern. The thing about the carpc system is that most of it is done by someone else, and if i want to make a new FE or something like that, it'll take too much programming, which isn't my expertise by any standard. Maybe a smart surveillance system.
    Jul 2006
    Hello
    Just a Idea.
    A control module for input, Car door (open close), Car ruf (open close), Car trunk(open close), car windows (open close), seet belt (open close), temp (in out), ligths, and so on.
    A electronic and software control module that allow the user to control all thing in the car.
    Bruno Pereira
    Dec 2006
    Quote Originally Posted by myrus View Post
    Hello
    Just a Idea.
    Bruno Pereira
    As much as that is a good idea, I (high school student self-taught) completed one of these projects that runs on USB in about... say... 2 weeks? There's no way that could take a whole year, it's just a generic USB I/O controller. Make it a (/an depending how you read this) HID device and you can control it easily with pre-made components in almost any language.
    Quote Originally Posted by Punky
    Thing is, most cars aren't that different after all. Typically, all of the manually controlled car AC systems have three things:
    - a fan speed control which simply powers or grounds pins for fans; from my research, ive noticed that typically there's 1 for the MAX AC, and 2 other ones that are used for the low (1 fan on) or medium (both on) settings.
    - a heat/cold control which just turns a door; you can easily control this with a typical servo
    - a couple vacuum activated doors that control where the air blows; if you get a solenoid driver in there, you can easily control all of these and even make custom settings.
    If you could provide relays to trigger the blowers, a servo control for the heat, and a vacuum actuator -- you've got it.
    That's just what I would do. There will obviously be time left over and climate control algorithms are pretty advanced, so throw in some temperature sensors with the bazillion extra inputs you'll have on a microcontroller and then you've got yourself a sweet project with lots of practical uses and a market. You'll make enough money to pay for the prototypes easily.
    Jul 2006
    Hello
    I was not talking in a simple USB I/O port controler, but an advanced one.
    You can make one that control just every stuf in a car, door, windows, trunk, windows, ligth, the car AC systems, and more...
    A system that can control and monotirize all the car, even the start of the motor, by the PC, you can also make an alarm system that can send via web or phone info to the user and vice versa, with the integration of a GPS send the exact possition of the car (car anti jaking, car alarm).
    I was thinking on a system that make by a integration of a Pc the user can control and monotorize all the systems of the car.
    On the AC systems you can make a manually controlled car AC systems with some algorithms in to a comple automatic.
    and that's just and idea.
    Bruno Pereira
  1. Replies: 4
    Last Post: 11-09-2007, 01:40 PM
  2. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  3. Parrot Bluetooth carkit for CarPC
    By m-ruiter in forum Road Runner
    Last Post: 05-08-2006, 07:40 AM
  4. Starting to make a Skin, need some help please
    By Slickrick2000 in forum Newbie
    Last Post: 03-10-2006, 10:46 AM
  5. False floor
    By i3igmind in forum Fabrication
    Last Post: 02-04-2006, 11:28 PM
