Results 1 to 10 of 11
Thread: Qualms with carputer in Sub box?
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    I did a quick search and didnt find anythig.
    Do you guys think there are any problems with putting a carputer in a speaker box? It's already taking up a lot of room There are only two problems i forsee:
    1. Vibration from sub would cause damage to mobo/cpu. I would probably mount the hdd somewhere close but not on the box.
    2. Sound quality would suffer.
    If you guys can suggest anything that would be awesome. I have a pretty small car (93 mazda mx3) so space is crucial. Thanks
    -rEegLer
    May 2006
    Calgary, Alberta
    Put your ear in there, see how you like it.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jul 2008
    Mechanicsburg, PA
    So you don't think there would be any problem that would arise with the pc?
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    my friend had an usblaster amp mounted on its boombox, and the amp gone dead! we tried to repair it, but not only the potmeters were damaged, the whole PCB with soldering points were shaked, and totally died! we gave up the repair project, there were too much damage on the board... and this amp had strong thick alucase, and were mounted on the sub, not inside! so, i think that you should forget this...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Jul 2008
    Mechanicsburg, PA
    good deal. It was just an idea i had. Thanks
    Jun 2003
    Memphis - TN
    well, I wouldnt recommend a HD mounted near it, but to tell my own story.
    I have had 2 amps mounted to a box with 2 12" subs for almost 10 years and Ive never had an issue with it.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    May 2008
    Hungary
    Quote Originally Posted by Custommx3 View Post
    i think this depends on the quality of the box... most of the cheap boomboxes are extruded paper. a good box starts from 15-16-18mm MDF board, and will never shake the mounted amp. but if you put the board inside, the low freq waves will kill it soon...
    May 2006
    Calgary, Alberta
    I don't think you picked up on my sarcasm. Your inner ear works on air pressure and reverberations to produce sound. So if you put your head inside the box, the sound pressure would probably be so intense it would bust your ear drums clean out and likely do the same to your hard drive or whatever else you put in there. There's way too much sound pressure inside those boxes to put volatile hardware anywhere near it. You might be okay with any non moving parts.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I wouldn't..................
    Leonardo Da Vinci
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    LMAO!!!! Computer in a sub box, did you forget that there is a HUGE magnet fixed to the speaker. I guess you wouldnt have a cooling problem for the computer if the box is ported...
  1. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  2. F/S: JL 12w7 Subwoofer with box!!! Pictures inside
    By neema12 in forum Classified Archive
    Last Post: 08-29-2005, 09:45 PM
  3. Wanting help with an ABC sub box
    By FyreDaug in forum Car Audio
    Last Post: 07-15-2005, 05:10 AM
  4. Box Loudness.... Help?
    By Harlanc03 in forum Car Audio
    Last Post: 06-08-2005, 11:10 PM
  5. Case design for a stowage box.
    By nibix in forum Fabrication
    Last Post: 07-10-2004, 06:12 PM
