In the car, 50/50 water antifreeze...
My desktop run's maybe 15% antifreeze (as a corrosion inhibitor)
Nope...the res is deep enough, and also very narrow front to back...if air did get 'injested', the pump/res would work most of it out again...
Just not pratical...I doubt the pump is strong enough to send coolant the length of the car and back anyways. And it's runs at 30 degrees with only 1 one fan running at 40% on the bench. Even on the HOTTEST days, it's going to run way cooler than an air only setup....
Water cooling a car PC? http://forums.overclockers.com.au/sh....php?p=9918776
[/QUOTE]
