Results 1 to 6 of 6
Thread: Motherboard connectors?
    Dec 2007
    Rochester Hills, MI
    Where can I buy a motherboard connector for this 7x2 pin connector for my audio. Its the same kind of pins you use to attach a power switch to your motherboard just longer. I can't seem to find them on newegg and I don't know where else to look. I just want a connector so I can have some wires running out the back of it. Attached is a picture of the connector from the manual.
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Would this be close enough?
    Failure is not an option....
    It's installed by default on every version of Windows.
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Quote Originally Posted by Mibix View Post
    you can find this connector in every component store, than solder the cables on it...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Mar 2006
    Colorado, but Canadian!
    You can also buy them in a form where you can put a ribbon cable between it and use a vise to squeeze it shut so you dont have to solder directly to the pins if you are bad at it.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2007
    Rochester Hills, MI
    Quote Originally Posted by FPeter View Post
    That is exactly what I need what are those called?
    May 2008
    IDC socket connectors.
  1. M2-ATX with Intel Atom Motherboard Issues
    By jeremy480 in forum M2-ATX
    Last Post: 12-05-2010, 12:28 AM
  2. MTB-057 Intel D945GCLF Mini-ITX Motherboard OS Installation problems
    By Fiberoptic in forum MP3Car Products - store.mp3car.com
    Last Post: 07-08-2008, 01:50 PM
  3. Which Motherboard to Choose
    By james33440 in forum General Hardware Discussion
    Last Post: 06-07-2005, 10:35 PM
  4. FS P4 ChainTech Zenith Motherboard
    By belezeebub in forum Classified Archive
    Last Post: 02-07-2005, 10:10 AM
  5. what type of cables connectors are these?
    By nutkin in forum General Hardware Discussion
    Last Post: 11-11-2004, 02:38 PM
