You are going way overboard for what you need. My laptop is a 2ghz core duo with raedon x1600 and I can run HL2 just fine. In fact it's quite hard not to sit in class playing CS-Source instead of paying attention. This is all done with 19v at 4.74amps. In fact I was playing oblivion at lowish settings with a decent FPS.
Anything you want to know about watercooling you can ask though. My home PC is fully watercooled, along with the past 3 PC's I have built and overclocked. This includes CPU, motherboard, & GPU being watercooled w/ a 2x120mm fan core. My last setup combined 2 seperate computers, both watercooled & connected to the same resevoir (~4gal container on top of the 2 computers) connected to a bunch of towers to evaporate the water for much lower temps, even without a fan.\
Also, you don't need to cool the SB, especially at stock speeds. Most motherboards don't even put a heatsink on that. Ram.... well I have yet to see a waterblock that I would trust to put on my ram without putting too much stress on the PCB of the ram or the motherboard connection. Just put a small quite fan to get airflow on the ram and keep it at stock speeds and you will be fine.
The only reason I used watercooling is to overclock anyway. For the most part, at stock speeds a decent fan/copper heatsink w/ good thermal paste is just fine. But when going from 1.8ghz to 3ghz daily and increasing voltages etc, you put out too much heat.
LinkBack URL
About LinkBacks
I'm definitely going to need some seriously beefed up
