Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Custom Switch
  1. #11
    Elsewhere
    This should help you: http://modzone.dk/forums/showthread.php?threadid=252
    If that information is accurate, you should be able to wire J6 on teh M1ATX to pins 1 & 2 of the "yellow wire bundle: and use the M1 to power your XBox on and off with the ignition.
    How about the Wiki?
  2. #12
    Newbie VTProphet's Avatar
    Jan 2008
    4 terminals...
    Jesuz...I am pretty sure your one button switch has the four terminals to determine whether the switch is wired for normally closed or normally open momentary applications. In other words, one set of terminals are used to open the circuit when the button is depressed (normally closed), or if the connections are wired on the other set of terminals, they are used to momentarily close the circuit when the button is depressed (normally open).
    Hope that makes sense and is correct.
    -Bob
  1. Custom Controller for OPUS 120W
    By walttoinfiniti in forum Power Supplies
    Last Post: 06-14-2007, 06:09 PM
  2. ****Celica Carbon Fiber Car Computer Finished****
    By hombredelassrta in forum Show off your project
    Last Post: 09-02-2006, 02:22 PM
  3. Control switch
    By warnockm in forum Power Supplies
    Last Post: 03-14-2005, 12:26 AM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
  5. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 01:13 AM
