Results 1 to 9 of 9
Thread: Hooking up Mac Slim Slot Load DVD Drive ($20 ebay) JAE50 to IDE40, HELP
    May 2007
    Once I figure this out, I promise to take some pictures and write a short article on how to do it. I am willing to bet somebody else has done this and knows what needs to be done. They may even have some pictures of this archived on their computer from before.
    OK So i got the iMAC SR-8186-B slim slot load dvd drive ($20 ebay). It came with the adapter board, but the board has 50 pins for the IDE connector.
    I have a 40 pin ide cable without a keyway or any blocked pins, and I believe it is supposed to be hookedup to pins 11-50 and then supply power, this is just from what i have read on here.
    Any pictures or articles I found in the forums here, are all now dead links or pictures.
    I just want to make sure i am hooking the ide cable up right, and also figure out how to power this.
    Here are a couple of picture of the back of the drive with the adapter board installed. the adapter board is the 820-1050-A adapter board.
    I drew on this picture to indicate where I believe the ide cable hooks up, but i was not certain, can anyone verify? Also I noticed the board printed with a + sign and also on the component as well.
    heres a shot with the cable plugged in, although i still dont know for sure that i have this plugged in right.
    Actually the way i have the cable plugged in is correct.
    I now have it working in windows and will take some pictures and then edit my first post to be more of a guide.
    I used this site for the pinouts: http://www.hardmac.com/articles/39/page3
    Here are some more pictures
    The way I have it hooked up the bios detects the drive as a Mitsu and windows detects the drive.
    When I put in cds it spits them back out a second later.
    Im wondering if I need to make use of ALL of the Ground and +5v sources. right now i only hooked up one of the +5v and one of the grounds.
    OK These last two will be my final and last test... wondering if maybe i need both grounds and all 5 +5v, going to connect the appropriate pins and solder wires straight to them.
    Elsewhere
    You need an adapter to connect this drive to a 40-pin IDE o work with a PC.
    And no, the connection you have is not going to work, but I'm sure you figured that out already.
    How about the Wiki?
    May 2008
    Hmmm, Apple, (c)1999, 50 pin connector... What you have there, I believe, is a SCSI connector. That's not going to work on IDE no matter what you do.
    Edit.
    Damn apple and their proprietary connectors. That might just be IDE after all. You might get it to work if you replace the interface board with something like this.
    May 2007
    I've tested everything i can think of, this drive is just broken.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    sounds like a bad drive.
    I might be looking at getting rid of mine if you are interested.
    May 2007
    I just picked up a much better slim slot load drive on ebay for $18. I will use the adapter board from this one on the new one once it gets here. it is a UJ-825-C
    Aug 2002
    fair enough. good luck with it
    May 2007
    I just re read my post, when I said a "much better one", I was not referring to your drive, yours may very well be top notch, I was referring to my previous drive that did not burn dvds, the one I just bought is much better than the one I previously bought, is what i meant.
    Aug 2002
    That's cool. I just thought you may have wanted a replacement.
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 12:50 PM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. FS: slim slot load dvd burner.
    By EsKALad in forum Classified Archive
    Last Post: 07-11-2005, 01:39 AM
  4. Slim slot load DVD ROM drive
    By jbors in forum Classified Archive
    Last Post: 03-17-2005, 08:31 AM
  5. Pioneer Slot Load DVD Drive Shock Resistant?
    By Bloomk in forum General Hardware Discussion
    Last Post: 01-15-2000, 05:46 AM
