I guess this would only be interesting for those of you owning a BMW E36 with the full OBC (18 buttons).
Anyway - wouldnt it be cool to "tap in" to the data that the OBC displays? The info available; Outside temperature, fuel consumption, speed and diagnosis codes.
I have lots of ideas for this (ofc :) ), but not alot of electronic knowledge :/
Anyhow, this is the information I have gathered;
Pinouts;
Plug 1 (X1070):
1 - Brake light switch
2 - Brake light switch
3 - Check control module
4 - Check control module
5 - Check control module
6 - Instrumentcluster (CHECK light)
7 - Check control module
8 - Starter
9 - Power, F23 5A
10 - Gong
11 - Gong
12 -
13 - Speedometer, X188
14 - Power, F45 7.5A
15 - SMG, Instrumentcluster
16 - Light switch (6300.0)
17 - GND
18 - Power, F31 5A
Harness 2 (X1071):
1 - EWS, Immobiliser control unit (CODE)
4 - Turn indicator/low beam selector
5 - Diag, TXD
6 - Fuel consumption
7 - Diag, RXD
8 - Power, F31 5A
9 - Instrumentcluster, speedometer
13 - GND
14 - Independent ventilation relay
And the info i could find from the Check control module;
- Left headlight
- Right headlight
- Wash water level
- Cooland level
- Light switch
- Left tail light
- Right tail light
- Brake light
So, alot of data available here. How to best gather it..? :)
