Results 1 to 3 of 3
Thread: TrafficBox FM9
    Oct 2004
    TrafficBox FM9
    Hi,
    currently the GNS TrafficeBox FM9 for FujitsuSiemens Loox n100 is special offered from GNS-GMBH, see http://www.gns-gmbh.com/shop/xtc/pro...6c89f9f05cff53.
    The site says this TrafficBox will only work with that PDA. Ok, the connector is for that PDA. But does anyone know if it is a standard(as used on the pc) serial signal? Thus when putting another connector on it, it would work just like a normal serial TMC reciever for the PC?
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    I dont know about that one seems like an odd connector, but if you can work out which pins are which you could get it to work.
    But I purchased this one cheaply http://cgi.ebay.com/ws/eBayISAPI.dll...m=110349996393 and when it arrives I will try and see if I can get it to work via USB.
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    Ok opening the unit up there is a phillips microcontroller which is what interfaces with the PDA. Connecting this to a TTL<->RS232 converter chip (such as the maxim 3232) and then to a com port allows hyperterminal to show the output from the device.
    Fox Mulder
    2004 Toyota MR2
