The PowerLine 0900-21 2000mA Car Cord Adapter has the highest amperage rating that I could find which connects to your cigarette lighter socket. Switch it to 4.5 Volts to handle anything you put on a 4 to 6 port USB hub.
I have seen a few projects for building USB Hub power supplies. Isn't this good enough to power 1 hub?
http://cgi.ebay.com/ebaymotors/12-5V...Q5fAccessories
I guess it also depends what is running on the hub correct?
Check out my CARPC: Project Diamond Plate
Quick Reference:
CPU Electrical Specs
Power Supply Calculator
Video Connections for newbies
Temperature Converter
Voltage Calculator
