Results 1 to 9 of 9
Thread: Automatic 555 timer, delay off
    Jan 2009
    Norway
    Hi
    I hope someone here may give me a little help, I'm building a car and misses a function.
    I need a timer, powered by the engine generator signal D+ (12v). When D+ is on, relay should go on. When engine switches off, D+ dissapears and the relay shold be hold for additional 0.5-2minutes aprox.
    Would be nice with a LED saying relay activated. And a switch to stop the timer and power off the relay. I have looked around the internet for a cheap kit or something, but most of the kits is either for 230v operation or with switch activated function.
    I thing the timer could be made of a very simple circuit board and a 555 timer. But I'm mostly an expert on automotive electrical wiering and not electronics..
    Thanks for any help
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    I've developed a relay controller than holds a latch for a selectable time period (by jumper)... Still interested? Send me an PM and I'll get you more info.
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
    Dec 2008
    Here's what you need:
    http://ourworld.compuserve.com/homep...tm#relay_i.gif
    http://www.circuitdb.com/downloadimg.php?fileID=206
    Description
    The two circuits above illustrate opening a relay contact a short time after the ignition or light switch is turned off. The capacitor is charged and the relay is closed when the voltage at the diode anode rises to +12 volts. The circuit on the left is a common collector or emitter follower and has the advantage of one less part since a resistor is not needed in series with the transistor base. However the voltage across the relay coil will be two diode drops less than the supply voltage, or about 11 volts for a 12.5 volt input. The common emitter configuration on the right offers the advantage of the full supply voltage across the load for most of the delay time, which makes the relay pull-in and drop-out voltages less of a concern but requires an extra resistor in series with transistor base. The common emitter (circuit on the right) is the better circuit since the series base resistor can be selected to obtain the desired delay time whereas the capacitor must be selected for the common collector (or an additional resistor used in parallel with the capacitor). The time delay for the common emitter will be approximately 3 time constants or 3*R*C. The capacitor/resistor values can be worked out from the relay coil current and transistor gain. For example a 120 ohm relay coil will draw 100 mA at 12 volts and assumming a transistor gain of 30, the base current will be 100/30 = 3 mA. The voltage across the resistor will be the supply voltage minus two diode drops or 12-1.4 = 10.6. The resistor value will be the voltage/current = 10.6/0.003 = 3533 or about 3.6K. The capacitor value for a 15 second delay will be 15/3R = 1327 uF. We can use a standard 1000 uF capacitor and increase the resistor proportionally to get 15 seconds.
    Quote Originally Posted by locked View Post
    Add a LED + current limiting series resistor, placed in parallel with the load you are switching.
    The value of the LED series resistor depends on how birght you want oyur LED to light up. A standard red, yellow or green LED has a typical voltage drop of approx 2V. This means there will be approx 10V across the series resistor. A typical LED current could be 10mA or 20mA.
    Resistor value @ 10mA: 10V/10mA=1kohm
    Resitor value @ 20mA: 10V/20mA=500ohm
    So just pick the resitor value you think gives the right brightness, but make sure not to exceed the maximum current from the LED datasheet.
    Not sure excatly what you want the switch function be. But if you want the switch to tunr of the delay function so it works like normal and tunrs on and off without any delay, then add a switch in series with the capacitor. When switched off the relay will shut down as soon as the ignition is turned off as there's no voltage to keep the relay turned on.
    I have added both the switch and LED + series resistor in the schematic below. The blue part symbolises the load you are going to switch. shold be connected differently if the load is connected directly to 12V instead of GND.
    If you want the delay to be very long you can use a darlingtontransistor or MOSFET trasnsistor which both draws much less base/gate current. This way you don't have to use a huge capacitor, but can instead add a resistor from in parallel with the capacitor to GND to control the discharge time.
    Dec 2008
    Here's a different circuit: http://www.astron.nl/~smirnov/poweroff.html
    A Power-Off Delay Circuit
    Originally, I had my MP3 box powered straight from the +12V line, and controlled it with the power switch on the inverter. That way, I could leave it running when stepping out of the car for just a few minutes. Of course, eventually I forgot to turn the thing off for the night, and found my battery dead the next day. That wasn't fun at all. So I decided to make a simple circuit to auto-power off the computer for me.
    This circuit delivers power to the computer as long as the key is in the ignition. After the key is removed, there is a delay of about 10 minutes before the power is cut. There's also a button in the dash to cut off the power immediately.
    The circuit is very simple & cheap, as you can see.
    IMPORTANT NOTE 1: there's a typo in the diagram - the "S" and "D" pins of the MOSFET are reversed.
    IMPORTANT NOTE 2: 50 Ohms for the first resistor is too small. Use 1 KOhm
    Feb 2009
    What does NOTE 1 say? I don't get it, can someone help me please?
    There is nothing impossible in the world :-)
    Sep 2008
    Western Australia
    The MOSFET will have 3 pins; gate (G), drain (D) and source (S). It's saying that in the diagram they have accidentally put them the wrong way
    Feb 2009
    oh ok, thanks I got it now
    Aug 2009
    Chandler, AZ
    Here's a product which provides adjustable turn-on and turn-off delays:
    http://www.wolstentech.com/timedelayrelay/
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    That's kind of odd having a variable resistor on the LED. Adjustable brightness was a concern and not time? hehe
  1. EBY701 questions and opinions!!!!!!!!!
    By HiJackZX1 in forum LCD/Display
    Last Post: 10-06-2009, 09:38 AM
  2. No automatic shutdown timer
    By jasonobrown in forum Newbie
    Last Post: 10-16-2007, 07:31 AM
  3. Replies: 19
    Last Post: 07-27-2006, 04:44 AM
  4. Timer Circuit
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 11-04-2005, 10:47 AM
  5. using a 555 timer to suspend
    By wizardPC in forum General Hardware Discussion
    Last Post: 12-27-2000, 01:58 AM
