Results 1 to 5 of 5
Thread: Switching system for domestic purposes
    Mar 2009
    Hi,
    Im trying to design a switching system like in your house controlled by a hub and then through the internet. So initial stages is coming up with a switching system. I just wanted different ideas, thoughts regarding this. The voltage im dealing with is about 12-15 volts 1amp or so. I was thinking of using a relay and the microcontroller cant be driven directly so i though you may need a transistor or something, so if anyone has ideas, thoughts or circuits in the switching area would be great, im only in planning phase so would look at different areas like costs involved, safety, feasibility
    thanks guys
    Dec 2008
    What are you trying to switch on and off?
    Does it use AC or DC voltage?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Look into relay boards, there is a USB Velleman kit that does that.
    Also have a look at the Fusion Brain on here.
    Fusion Brain Creator
    Mar 2005
    fusion brain is perfect for this and can be controlled remotely via website.
    Mar 2009
    thank you for your replies and posts........so in short we have a controller and a relay for switching, controller cant directly drive a relay so we need a transistor... i was looking into x10 controller which comunicates through the power lines in a house, what would be some of the safety electrical standards involved like would this cause disturbance to someone next door, can this cause any damage to the setup at home....where could i check these standards
  1. 2001 C5 Corvette Car Computer/Audio System
    By modena0 in forum Show off your project
    Last Post: 09-07-2006, 10:18 AM
  2. Ground audio system to battery??
    By eddie in forum Car Audio
    Last Post: 05-30-2006, 03:34 PM
  3. Escalade PC and Audio System Install
    By accentsound in forum Car Audio
    Last Post: 11-02-2005, 12:50 PM
  4. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
