Easy solution would be to find a software/hardware package to interface with your car (all cars 96 and newer have the same OBD2 connector) with this you can monitor more than just temperatures in your car. hit up a search engine with USB OBD2 or USB OBDII.
Second issue is the carputer, its too bad u didnt consider the thermal sensors when you purchased your main board, but there is an easy solution. The overclocking community has designed many systems to monitor temperatures of your computer, my suggestion is to ask around at overclocking forums about thermal monitoring, they will likely send you in the right direction, and you may even be able to use the same system to monitor the temperature of certain areas of your car.
LinkBack URL
About LinkBacks
