Results 1 to 9 of 9
Thread: RCA/Stereo input, RCA output lowpass crossover?
    Sep 2007
    Export, PA
    Who would be interested in taking a stab at this?
    I'm looking for someone to design and build a lowpass crossover for the center/sub output of the computer, since no computer's outputs are lowpass or highpass capable......always full range
    i understand i could just buy an electronic crossover and call it a day......but those are expensive and do more than i really need...
    also, anyone know what computers normally provide for maximum output voltage from the sound outputs? like some headunits have 2V, soem have 2.5, some have 4, etc...
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    honestly you'd prob be better off yo buy one... to pay for someones time to design, build, test, and troubleshoot on top of parts would prob end up being a lot more than a mass produce item. Unless someone wants to make one just for the challenge,
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by bratnetwork View Post
    this.
    plus, there's circuits out there to do it. do some research.
    FLAC WuNgUn's Avatar
    Sep 2007
    If it's a 4.1 or 5.1 or 7.1 card, it's already doing the lowpass for the sub...
    Sep 2007
    Export, PA
    negative sir....i had speakers hooked up to that output.........its full range with the ALC888
    Sep 2007
    What sound card are you using??
    You realize on the center/sub jack, that the center is full range on one channel and sub out is on the other channel (i.e. left side)?
    Basically, two mono outputs on the jack...
    Sep 2007
    Export, PA
    Again....
    Realtec ALC888
    I had a pair of speakers on the center/sub jack. both sides were getting full range.
    Sep 2007
    Obviously there is something wrong with it, your drivers or the way you have it setup...
    XP? Vista??
    What speaker configuration are you using in the Windows speaker properties?
    Make sure it's 5.1 or 7.1
    Jun 2009
    I also have Realtek and my subwoofer output puts out all frequencies. Is it suppose to act as a low-pass filter? I have Windows XP.
  1. Replies: 5
    Last Post: 10-05-2011, 06:45 PM
  2. Sound Processing and X-Meridian
    By qpwoeiruty999 in forum High End Solutions
    Last Post: 01-13-2009, 08:15 AM
  3. Replies: 3
    Last Post: 10-18-2007, 04:43 PM
  4. What's the best PCI card to use for Audio and Video RCA output??
    By ES20 in forum General Hardware Discussion
    Last Post: 10-01-2001, 08:32 PM
  5. can I use an amplifier for rca input??
    By sheriff in forum General Hardware Discussion
    Last Post: 03-23-2001, 09:03 AM
