Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 79
Thread: New Product Idea Automotive USB Hub
  1. #11
    Newbie schatzy62's Avatar
    Apr 2009
    Central Mass
    Here is the power supply you need.
    http://store.mp3car.com/Carnetix_CNX..._p/pwr-016.htm
    Small in size and can be used without the Carnetix powers supply and they output up to 3 amps.
    I will be installing two of these in a small project box for a total of up to 6 amps output.
    Then use two of these.
    http://store.mp3car.com/4_Port_USB_H..._p/adt-011.htm
    To hook them up take it to your local Radio Shack and buy the correct plug to fit in the power input hole. from that make you self a power wire.
    Now you are all set and have 8 powered USB, that will power just about anything you could put on it.
    Schatzy62
  2. #12
    Jan 2005
    Quote Originally Posted by colin View Post
    Simple circuit as somebody mentioned. Attach a simple 7805 to the 12v power line with a heatsink. Power the hub off your output. Simple, really. If not, grab 5v from the PC? Most devices are raping your 12v rail, the 5v needs some use, might as well power a ton of USB devices!
    I have to agree I am using 7805s to power my hubs actually I had a couple directly powering a couple of stubborn usb devices in my last car
  3. #13
    Nov 2007
    12v-powered 7-port hub? Where do I sign up?
    I tried to cobble one together from a regular 7-port hub and a 2-amp USB-like charger, but the combination failed. So yeah, I want one. Bad.
  4. #14
    Newbie VYSSO3's Avatar
    Dec 2008
    Melbourne Australia
    Hey,
    Why not implement an LM (eg LM7805) based Voltage regulator to create a regulated 5v DC out (handfull of components) and use a regular 'Ritmo' style 7 port hub that takes an external 5v plugpack? Really not that tricky...
    Its been a while but an LM7805 can pump out 3A quite comfortably. The fact that we have a flat full DC wave to begin with makes life even easier...
    Check this out... I doubt this would cost more than $2 to make.
    http://booksbybibin.14.forumer.com/a...17_post32.html
    Cheers,
    George
    Fighting for peace is like screwing for virginity...
  5. #15
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    What's wrong with this? They make a 4 port and 8 port model as well.
    http://www.usbgear.net/productdetail...G-12U2ML&cats=
  6. #16
    Dec 2006
    India
    Quote Originally Posted by VYSSO3 View Post
    While 7805 looks cheaper and easy to implement, being a linear regulator, it is notoriously inefficient. It would be a very bad choice to put into design/production especially in a CarPC environment.
    Consider 1A loading per port, each 7805 will dissipate around 7 Watts at 12V I/P. Multiply that by the number of ports and you easily have a furnace inside your car...lol. They need loads of heat sinking as well...In short, that is too much power wasted for nothing. IMO, you should be looking at nothing less than a switching regulator. Linear regulators like 7805 are so last century.
    Another point to note is that most well engineered USB hubs control the 5V VBUS line on each port individually.They call it PPPC (Per Port Power Control) and has obvious advantages. So it is not just as simple as jacking up the amperage on each output.
  7. #17
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Sure, they're inefficient, but they're cheap, easy to install, and they'll work. Just heat sink them. You're unlikely to be loading 1 amp per port, so that's a worst case situation.
    A switching regulator is more elegant, of course, and if you just have to have one, mp3car sells a point of load regulator for about $35 from Opus or a similar one that you can add on to a Carnetix P1900 or 2140.
    Want to:
  8. #18
    Low Bitrate chrislamb's Avatar
    Nov 2007
    Warwick, UK
    Another point to mention is switching OFF of the hub.
    It needs to switch off with the PC and not with the car, otherwise the PC throws up USB errors as it is still running and the hub gets switched off by the car.
    Not a problem at switch on as the PC starts later than the car and the hub has to wait for the PC.
    MINI COOPER S PRO
  9. #19
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Lok View Post
    Hey guys,
    I was doing an install this weekend with a customer who wanted to have literally every accessory possible for a Car PC system everything from OBD to a full deskjet printer and the problem that I ran into (I am sure many of you have too) was that I did not have enough USB ports, so I had to purchase an inverter ($35) and a cheap USB hub ($20) to add the additional ports to the system. This got me thinking about a new product.
    Now from what I understand a Hub operates on 5V and a Car operates on 12V-24V so to design a hub for automotive applications can't be that hard. I alrady have some development tools to get me started on the HUB side but now I want to start working on the power side to insure we are getting clean power to the USB hub. What I imagine the product to look like is a 7 port hub with a cigarette lighter for the power, and a USB Type B port to connect to the host computer. I am not sure how much the device will cost yet but I don't think it would be worth it unless it was cheaper than $50 or $60 bucks. I know there are a few people out there that already have a similar products but I think they sells for a ridiculous price. Any suggestions comments are welcome.
    Most hubs can be powered off the ciglighter, but alot of adapters dont hit 5V, and the ones that do only have a small amprage. Some people have stated that a HUB will run perfectly on 4.5V, but I really dont trust that. I dont trust the inveter method either, as I tried it and went through almost 5 or 6 hubs. The best thing to do is simply buy a 15W PSU from OPUS that can handle 3 hubs as long as their all 1 AMP per hub. In my setup I have one 7 port hub at 2 amps, then the SOHO echo cancel card. Maybe you should focus oin making a cheap power adapter that is true 5V, that way people can go with a hub they trust and have more variety. I think if you can come up with a regulated 5V adapter with at least 3 or 4 amps, that would be awesome.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  10. #20
    Apr 2009
    Central Mass
    Quote Originally Posted by Dougw133 View Post
    Sounds like a good deal untill i read thru the actual specs and and then there is a 500 mA limit to each port. Each of the three WD Passport Drive i have will take 1000ma (twice what each port is regulated to.
    And for that price i could do better with what i suggested in my earlier post.
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  2. Replies: 2
    Last Post: 09-26-2005, 09:59 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  4. Powering an unpowered USB hub?
    By Squiddy in forum Input Devices
    Last Post: 09-02-2004, 04:37 PM
  5. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 06:06 PM
