Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 79
Thread: New Product Idea Automotive USB Hub
  1. #31
    Feb 2008
    Well I'm planning to use powersupply's output?? Isn't it possible?? I found a 4 port usb hub that has an extra power input... power input is ofcourse 5V. And in my new system I'm planning to get 5V directly from the powersupply... This is very easy I Think. You only have to use around 5 meters of power cable and a high quality 3-5 meters of usb cable? Am I wrong??
  2. #32
    Vendor - Qube colin's Avatar
    Dec 2006
    Its possible, that's what Im doing. I bought 2 powered hubs, one of which will be at the front of the car. I ran a 72" molex extension and a USB extension cable up there to give it power.
    Haven't installed yet, but it should work.
  3. #33
    Jun 2009
    anyone ever try this one?
    http://www.powerstream.com/dc6.htm
  4. #34
    Nov 2003
    Marietta, GA
    MikeH
  5. #35
    Jun 2009
    Quote Originally Posted by MikeH View Post
    seems a little overpriced especially considering it only puts out 500mA per port, I would expect more at that price range.
  6. #36
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by TheDrake View Post
    why would you want more than the recommended USB max per port?
    Live mp3Car Facebook Chat
  7. #37
    Nov 2007
    Quote Originally Posted by Sonicxtacy02 View Post
    To support passive hubs downstream.
    I'd be a little suspicious of using USB cables to carry more than rated power though.
  8. #38
    Nov 2007
    Also, I just bought one.
  9. #39
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I was about to say the same thing..... If a device has to use more then that, then it will have a port on the device for its own power source. All hubs only put out 500ma per port. Its the standard for all hubs and the devices made for it.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  10. #40
    Mar 2006
    Colorado, but Canadian!
    That's the maximum allowed. Not the maximum recommended, but to be USB certified it CANNOT supply more than 500mA per port. This is the best the USB standards allow for legally and safely considering the specifications regarding USB cables. (Seen those ribbon reels of USB/Cat5 cables? I think 500mA is even a stretch for some of them...)
    Quote Originally Posted by HiJackZX1 View Post
    Not all hubs put out 500mA. That's the max they can. If you plug a passive hub into a USB port, it can supply 500mA maximum to all devices connected to it. It cannot tell the system "I am a 5 port hub, I need 2.5A so I can supply the rest of my ports with 500mA", so it is split. Split it again and so on and so on.
    Not sure if that's what you meant, but "maximum" really needs to be used.
    1.9in x 2.9in -- 47mm x 73mm
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  2. Replies: 2
    Last Post: 09-26-2005, 09:59 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  4. Powering an unpowered USB hub?
    By Squiddy in forum Input Devices
    Last Post: 09-02-2004, 04:37 PM
  5. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 06:06 PM
