Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: My $15 12v Automotive 7-port USB hub
  1. #11
    May 2009
    San Diego
    Do you have a schematic for the DC step down circuit or a website where I can buy one?
  2. #12
    Jul 2009
    Cool. So when you turn off your ignition do you go into standby or hibernate on your PC?
  3. #13
    Vendor - Qube colin's Avatar
    Dec 2006
    The power converters are on eBay as posted in another thread, no time to look. They're about $8 shipped, maybe less.
    When I shut off my ignition, I hard-off. I don't care about the "possible" problems. If my car goes off, so does the computer. I do have a switch that will hold power but that is risky business. My bootup times are about 10 seconds, so turning on is not a problem for me.
  4. #14
    May 2009
    San Diego
    Quote Originally Posted by colin View Post
    I think this was posted before: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT but it's about $15 shipped. Was this the one or is it a different one?
  5. #15
    Dec 2006
    That's the one, but it only came to about $8 shipped. To Canada.
  6. #16
    Sep 2008
    Fairfax, VA
    Guys you're all going overboard on the "step down converter." It's not hard. 5 volt linear regulator, i.e.
    http://www.radioshack.com/product/in...ductId=2062599
    They come up to 5 amp capacity. Simple to hook up, 3 wires (+12 in, +5 out, ground). Add a cap before and after and you're golden. It's all explained in the datasheet:
    http://www.national.com/ds/LM/LM341.pdf
  7. #17
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by theshadow27 View Post
    Yet you link to a 1 amp version. LOL
    Also with a 3A or 5A version you will need a rather large heatsink.
    So it's better to just buy a prebuilt regulator.
  8. #18
    Dec 2006
    The problem with converting 12v to 5v at 3A is heat.
    Think of it like this, you're dropping 7 volts to get 3 amps. That's gonna be HOT.
  9. #19
    Dec 2008
    if you used a little pricier switching type regulator you can eliminate most of that heat, can't you?
  10. #20
    Dec 2006
    That's exactly what was used...
    theshadow27 proposed a linear regulator instead.
  1. 12v USB Hub - $29.99 :-)
    By kapone in forum General Hardware Discussion
    Last Post: 10-07-2009, 12:51 PM
  2. USB Hub Doesnt Work On Boot - Help
    By we87 in forum Input Devices
    Last Post: 08-03-2008, 12:12 AM
  3. USB hub from touchscreen port?
    By sama in forum General Hardware Discussion
    Last Post: 04-11-2006, 07:23 PM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  5. usb hub with 12v psu
    By etrik in forum General Hardware Discussion
    Last Post: 06-30-2001, 02:06 AM
