When I did my most-recent setup...I used a 6-pin quick-disconnect set of connectors and used 5 of the pins...
-Ground
-Constant +12v
-Switched +12v
-PC power switch +
-PC power switch -
Getting the PC out of the car is just unplugging this connector, the DVI, and the various USB cables. I can get the PC out of the car in like 90 seconds.
I agree that everyone should have some kind of a quick-release connector. It just makes the maintenance on it so much easier. As for your "universal standard" idea...I don't think it's a one-size-fits-all solution.
In my case, I run the DVI to a scan converter that's installed right under the PC so my DVI cable is only about 6 inches long.
I also agree with csfile that finding an unobtrusive route for what is going to be a very thick cable will be a challenge in many cars.
I have USB cables run under the carpet down the center of the vehicle. The audio cables run down the driver's side door sill and the power cables from the battery run down the passenger side door sill. I know that none of these places could handle a 1"+ cable.
LinkBack URL
About LinkBacks
