View Poll Results: How likely you would buy and use this product?
Voters
15. You may not vote on this poll
  • 0 - I will NOT be using it no matter what
    4 26.67%
  • 1 - I'm not sure it it will work, I will not buy it
    4 26.67%
  • 2 - I like the product but do not wanna pay for it
    1 6.67%
  • 3 - Not interested now but maybe will change my opinion later on
    2 13.33%
  • 4 - Im Neutral, I dont Know if I will be using it
    0 0%
  • 5 - Interested (maybe will buy within 1 year)
    3 20.00%
  • 6 - Interested ( 6 Month to buy)
    0 0%
  • 7 - Highly Interested (Ready to buy in 3 Month)
    0 0%
  • 8 - Extremly Interested (Ready to buy TODAY)
    1 6.67%
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: proposed single wire and connector standard for CarPC
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    Lightbulb proposed single wire and connector standard for CarPC
    Hey all, I keep upgrading wiring for my car pc and it sems that thare are some problms w. regular comp conectors ex: USB and especially USB mini on a road as if you drive like crazy they get loose Also not all cakves are shileded so you may see some interferance. (sure you can get milco screwon usb and good shielded cables for everything. U probably will spend 200-300 on them alone + no gurantee you get good ones from the first try.
    So im thinking to start pushing soething like unified pre made cables that are spesifically designed for car pc needs + modular + easy to disconnect + 1 cable for all.
    Ex: you have PC in the trunk, most likely you will neeed those wires up front:
    1. +12V (for monitor and etc, strabilized power, not from main bus)
    2. +5V (for your USB hubs)
    3. -Rail (Just in case you dont have access to it up front + to eliminate noise)
    4. USB Cable for touch screen (4 separate wires inside)
    5. USB Cable for perefireals (since it is not recomended to use same cable w. touchscreen)
    6. Reset Swiitch for your PC
    7. Start Switch for PC (non nessesary but if u got regular PSU u will need it)
    8. VGA Cable (6 - 9 wires inside depands wethere VGA or XVGA)
    9. DVI (Just in case you have good monitor, I dont know wire count for this)
    10. Microphone Extra shielded
    11. Audio Wires (this is questionable if it is smatt to wire them up front + other things, dont compfront me on audio, we just drop few fhileded wires there just in case to deliver 2 stereo channels, thats 6 wires)
    12.Remote or Ignition (to start you smart PSU, if you remote wires are in front of the car)
    So at this point I came up with 12 categories of wires that can be used for CarPC needs to conect your back to front of the car. You can run then induvidually but I think It is much better to have well made special cable that will include all of them, gonna be a thick one but guranteed to work. Will have military circular screw on connector that will not fall off if you drive roughly, + proper shileding everyehere, 1 shiled for category + 1 shiled for whole cable.
    Then you can use pigtail cables on you PC box to wire out all your single milco connector. Use soft epoxy to secure conectors on PC. Thne use premade cable and drop it to the front of the car, there connect it to premade cable header to output and convert your connectors for useful way.
    So if you doing you own car you can ensuire you get cabling right from the first time and dont waste too much money on exprermenting. If you are an installer you will speed up your install time and will have easy way to troubleshout the onnection.
    What do you guys think? Should I push this project? Any commnts?
    Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    That's a pretty cool idea, but honestly I don't see much point to it. Have you seen the prices of even the "cheap" circular mil style connectors? Granted, if I was removing my carpc every single day it would be worth it, but generally I go at least a year inbetween having to do things like that.
    Don't forget you're not going to be able to pass VGA/USB through the same connector as your monitor/peripheral power, not to mention audio without issues unless you pay for the individually shielded contact style connector. You CAN get that style connector, we use them at my work all the time. It'd be amusing to have a $400 computer with a $200 connector
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Jun 2007
    hehe well connectors are $40 each and u need at least 4 for full assembly. So 160 for connectors and prolly another 100 for making the cable (i still have to check how much the company would charge) if we happan to buy 1000 units the bric goes down dramatically, i think we cn buy same connector for $15 which is pretty resonable given thta it has extra shield and high power terminals.
    From one prespective yes its expemsive, but from another for my first VGA cable I paid $14, got ghosting, bought $25 one, no ghisting but signall in not stead on black color, fibaly bought $80 and got crystal clear image umm that $119 just for VGA add gold plated USB cables each I need 2 to get around for 1 link and I have 2 links, each cost about $25 so extra $100, now power cable I think I have AWG16 pairs for monitor and for power switch coted me another $60, + some extra for small wires
    so
    119+100+60 = $279 jsut for wiring alone. So 260 VS 279 sound close to be the same (also I didnt just made up the numbers I actuallt totaled what I spent (didny even know that the number would be this clsoe))
    As to need to swap comps, yep i crazy on updates so i take it out like every other week. But even for general Install its much easier to lay one wire that can serve all the need rather then thinking what cables did i forget =)
    Variable Bitrate csfile's Avatar
    Feb 2009
    I'm imagining a pretty thick cable. I would think that would be hard to route. With all the individual cables, I was able to route them under the carpet without any noticeable signs. The fat cable would probably leave a nice bump.
    I like the idea for ease of use, since wiring was one of the most difficult parts of my install. But I also like the flexibility of having individual wires. I could see this as being very useful for some people. If you do make one, my opinion may change though.
    Jun 2007
    well yes gona be at least half inch in radius. In my case after taling my car apart I found i have plenty of space in weire tranches, which applies to all Mercedes models =), but no way to put it under carpet.
    as to making one, I will defenetly be doing one for myself, im jsut not sure on what i will do yet, im set with locable connector for sure.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Looks like an expensive solution for a problem I do not have....
    My systems is in and functional with no special cables.
    TruckinMP3
    Read the FAQ!
    Jun 2007
    mew new headligh eyebrows lighting is more expansive :P
    Jun 2004
    Westminster, MD
    Quote Originally Posted by tempgp View Post
    expensive perhaps? Not sure how expansive really applies to that...
    Jun 2007
    expansive can be applied to anything, how relative that thing is thats whole anopther question
    Jun 2004
    Westminster, MD
    So is that a yes or no? Perhaps don't drink before posting? :P
