Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Building a custom cable for a Xenarc 706TSV... impendance question
  1. #11
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Just in case, did you verify that the existing cable was in fact a pin to pin connection and not a transposed connection? Seen it before with some manufactures.
    Apart from that I don’t have much; I’m surprised that it would not show a picture in some fashion.
  2. #12
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    I would second the check the original question cable comment...
    Also, I stand by my original comment-at those frequency's cross-talk is going to be your biggest problem. Not just shielding the cable itself but shielding each line from the other lines.
  3. #13
    Constant Bitrate Pseudo Nim's Avatar
    Apr 2005
    in the snow
    Yeah, I walked the original cable with a multimeter... didn't SEEM to have any cross pins. Unless something connected to 2 pins, but I kind of doubt that.
    I'm thinking maybe it's simply too long? Wonder if I should just cut it, resolder in the middle and see if it makes the situation better or not.
    justchat: good point re: crosstalk, but I'm not sure how to avoid that - that will be the case for any ribbon cable, no? So maybe the cable choice is wrong from the start - but I'm not sure how to dodge that problem, since I _need_ a flat cable for this.
    Doko ni datte, hito wa tsunagatte iru...
    My BMW 335xi install
    My Subaru Impreza install (now retired...)
    Realtime audio freestyle hiphop battles online - www.letsbeef.com!
  1. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 12:16 AM
  2. Question: Powering Xenarc from Morex 80w?
    By eleventh in forum Power Supplies
    Last Post: 12-05-2004, 08:58 AM
  3. Xenarc Touch screen Question.
    By IntellaWorks in forum Input Devices
    Last Post: 11-10-2004, 12:19 PM
  4. Replies: 2
    Last Post: 08-09-2004, 08:36 PM
  5. Mounting my Datalux and VGA cable question
    By gfoulks in forum LCD/Display
    Last Post: 08-26-2002, 11:35 AM
