Results 1 to 7 of 7
Thread: Lilliput power button
    I've bought a lilliput (widescreen) and was wondering if anyone knew of a circuit to make the powerbutton from the lilli also trigger a relay or simulate the press of the pc power button.
    My carpc uses a laptop powersupply but to save having to press the pc on and monitor on i was hoping to press just the one.. but the screen one as it looks like its meant to be there..
    I remember back in the days using an old lilli someone built a circuit to make it turn on when the ignition was on.. Maybe the same person may be who i need to talk to.
    Cheers in advance
    and sorry if this has been done.. search facility sucks when ou dont really know what to search other than lilli hack, power button etc.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    The power switch is just a momentary switch. Just wire it in parallel with the power button on your computer.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by nobb View Post
    not if the voltages are different
    cablammy so measure voltages and if the same wire in parallel..
    Wicked
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I wouldn't recommend it as they are different power sources. Most of the ACPI power headers are for a switch that pulls to ground anyway. A good way would be to find something on the board that has power when it's on (close to the supply section), then depending on the volts (5, 12..) use that to supply a constant to pulse circuit using a resistor, capacitor and small reed relay or optocoupler to isolate it.
    Low Bitrate Meltz014's Avatar
    Mar 2005
    Denver, CO
    You could use a momentary DPDT (double pole double throw) switch. This would essentially be two separate buttons that run off of the same push, that way you could wire them both up and they wouldn't interfere w/ each other.
    The circuit diag would look something like this
    lilli+____---------_____lilli-
    PC+____---------_____PC-
    Aug 2007
    Roma
    use the remote control and press 588998 and you see a secret menu...
  1. Auto Power On 619 Lilliput - Programing Guide
    By Anointed in forum LCD/Display
    Last Post: 10-23-2010, 06:26 AM
  2. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  3. Shuttle power button?
    By mazda3uzr in forum Power Supplies
    Last Post: 02-06-2005, 05:36 PM
  4. ITPS reprogramming ?
    By naruto in forum Power Supplies
    Last Post: 11-26-2004, 02:19 PM
  5. how can I make my own lilliput power button
    By bmwperson in forum LCD/Display
    Last Post: 09-09-2004, 01:06 AM
