There is no easy way do do this. You would amongst other things need a sepperate power source for the keypad device, that charges while the engine runs.
On cars where this is an option from fabric, they do not cut any power but the block the ECUs of the car to go active. Like an anti-theft system.
Now then... splicing into the ECUs is a risky business and if you're NOT an electrical enginere from your very own car moddel. I would strongly suggest that you drop this issue.
I had a extreemely modified car once that I did some programing on. We had the whole performance bit of the car be diagnosed and configured from a PDA. (This was back in 2000 and CarPCs where not that big then).
The car ended up with three power modes...
"Wallet" - power cut at 3000 RPM and max speed limit at 30 km/t
"Wife" - Power cut at 4800 RPM and max speed limit at 150 km/t
"POWER" - No Power cut, no speed limit. Just pure 634 HP at the rear wheels.
This where in an extreemely modified Volvo 960.
The whole job was a hell to acomplish and I ended up with frying 3 ECUs before we got the car as we wanted it to be.
LinkBack URL
About LinkBacks
