Results 1 to 10 of 10
Thread: Auto ON inverter
    Oct 2007
    Auto ON inverter
    Hi,
    What do i need to make a auto ON future on power inverter ? The idea is :
    when i turn the ignition key to "acc" to power it on, by default it powers on via switch.
    maybe a relay of somekind?
    thanks
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Run it off a relay tied to your ACC line. Go ACC - relay signal input, battery + to relay input, relay output to inverter input, and relay signal output to ground.
    Be SURE to fuse the inverter wire of course.
    RevFE
    My Shop
    Constant Bitrate leo_bergamo's Avatar
    Apr 2009
    With my setup I replaced the on/off switch of the inverter with a SPST momentary remote switch on the dash and an automotive relay. So when the SPST momentary switch on the dash is pushed it then powers the inverter witch then powers the PC. When the PC is powered on it then energizes the automotive relay wich will keep the circuit closed while the PC is powered on. The relay is wired to a 12V lead from the PC's power supply. For this to work though you will need to have your PC setup to automatically power on when it detects AC from the inverter.
    Apr 2009
    Quote Originally Posted by malcom2073 View Post
    As malcom2073 said:
    "Be SURE to fuse the inverter wire of course"
    Is very important also!
    Oct 2007
    i have a switch that is mounted in the dash, with it i control the whole setup, but i want it to be "automated". what kind of relay should i use?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    SPST relay will energize the switch and turn it on automatically. Make sure you use a relay with the same or better rating as the switch. The rating is usually written on the switch.
    This will only power the inverter automatically, not the PC. You'll still have to turn the PC on.
    Want to:
    Oct 2007
    i have the PC BIOS configured on Auto ON after power failure, so it turns on automatically after i turn on the inverter so i'm good.
    Newbie RockWilder's Avatar
    Nov 2009
    So help me out on this one.... i am not too clued up with this kinda stuff.
    Do you have a diagram of this install, cause maybe i'm thinking of this the wrong way around. Wont the relay fry if you had to push the power button while the Pc is on?
    Dec 2006
    Nov 2009
    Sorry dude i kinda read Leo_Bermago's reply wrong. My mistake.....i see what he has done. Nice one by the way......i neva thought of that!
  1. Power Issues with inverter
    By kostyanj in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 08-01-2007, 10:18 PM
  2. Replies: 7
    Last Post: 02-08-2007, 04:39 PM
  3. Inverter
    By shaylin in forum Power Supplies
    Last Post: 01-21-2007, 10:23 PM
  4. Replies: 5
    Last Post: 02-04-2005, 11:07 AM
  5. inverter question
    By johnyeros in forum Power Supplies
    Last Post: 05-21-2004, 03:21 PM
