Results 1 to 10 of 15
Thread: Remote GSM control
    Dec 2009
    Remote GSM control
    Heya,
    I looked but wasn't able to find much on this topic. I am interested in controlling a number of things on my car remotely using my cell phone. There are many instances in which this has been done to start the car remotely, using a prepaid cell phone and such. This is exactly what I want, except for it to be able to control multiple functions.
    There is a device over at gsm-auto.com which does exactly this, but it only has two relays. It includes security, etc., but again, only two devices. Can anyone thing of a way to mimick this device, but for many different relays? I.e. call the number, press 1 to start the car, press 2 to unlock it, press 3 to initiate auto destruct sequence etc..
    Does this make sense? This can be easily done with a FOB, but with a cell phone I feel like it would be trickier. Has anyone done anything like this?
    IHateMayonnaise
    Jan 2008
    Dartmouth, MA
    Check out my worklog. My setup is probably way overkill though. The link is in my signature.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Dec 2009
    Thanks for the reply. I only skimmed, but I didn't see anything relating to remote GSM stuff. Where is it?
    I found this site:http://www.serasidis.gr/circuits/sms...controller.htm, where someone did pretty much exactly what I am looking to do, although their instructions are not all that intuitive.
    I went ahead and bought an AVR programmer, cause i wanted to get into this stuff eventually. Are there any other websites like this one that offer more...instructive instructions?
    Jan 2008
    Dartmouth, MA
    In my setup, I have a sheeva plug which is always on and always connected to the internet. A server in my house has a program I wrote on it which is always logged into AIM. I text the AIM screenname and the server forwards the command to the car across the internet.
    If you don't already have a sheeva plug in the car though, it's really not worth it to buy it for such a limited use.
    Even though, it may end up coming out cheaper than an AVR gsm development board.
    Jan 2008
    Dartmouth, MA
    Dec 2009
    Quote Originally Posted by PaulF View Post
    Well the AVR controller was just 22 bucks from adafruit, and the board itself should cost like 3 bucks. Yeah I saw that article..he doesn't fill in many details though
    Jan 2008
    Dartmouth, MA
    That article does give you a full schematic and the source code. You can definitely make that work.
    Dec 2009
    My question is how he picked the data connections on the phone. I don't plan on using the same phone, how can I tell?
    Low Bitrate majasticmoose's Avatar
    Dec 2009
    A simpler idea. A DTMF decoder. What it does is every number on the dial pad a has corresponding tone (a DMTF tone) the tells the tower where to place your calls. So once you call "your car". The output of your phone in your car will be hooked up to a DMTF decoder. after the car "picks up". Any number you press will play a tone make the DMTF decoder trigger a relay which could start a car, unlock it, etc. It's very simple. ( and it sounds like what you are describing).
    http://jpl995.com/DTMF-DECODER-CONTR...C-P423954.aspx
    Here is one that has a security code (so anyone with your car's number can't start it) and it accepts +12VDC.
    Andrew
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by majasticmoose View Post
    Andrew
    That's an awesome idea. Hmm....
  1. carpc iphone remote control options?
    By soundman98 in forum iPhone and iOS
    Last Post: 12-25-2009, 01:00 PM
  2. Project: DIY Dual Remote - 2 remotes in 1!
    By WarriorRocker in forum Input Devices
    Last Post: 04-03-2008, 10:15 AM
  3. XENARC 700 TSV Remote Control
    By kbreeden in forum LCD/Display
    Last Post: 08-08-2005, 09:18 AM
  4. CarPC Remote Control feature
    By liquid_smoke in forum PhoneControl
    Last Post: 04-06-2005, 02:21 AM
