Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Garage Door Open/Close sensor
    Jan 2008
    Dartmouth, MA
    I'm working on making my garage doors automatically open/close when I pull up to them.
    What kind of sensor would I use to determine whether a garage door is opened or closed?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Jan 2008
    you could use a momentary switch with a actuator arm, or maybe a optical sensor near the top of the doors travel?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I use a magnetic reed sensor on mine. When the door is down, the magnet is next to the sensor.
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Use a reed switch or a capacitive proximity sensor.
    Both will work great. Optical sensors will get dirty and then read incorrectly, conventional switches (actuators or momentary) may also work but I like to keep things as simple as possible and read switches and prox sensors are about as simple as it gets and they work great for this type of application.
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    You should use two sensors, one at the top and one at the bottom. Then your opener can determine if the door made it all the way up or not. I know my piece of poop Wayne Dalton iDrive garage door opener acts up quite a bit in cold weather.
    Mar 2006
    Colorado, but Canadian!
    Just be glad you dont live by Norad. Garage door openers in our neighbourhood just randomly go up and down...
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by ThunderStick View Post
    LOL, my iDrive acted up the first winter about 6 or so years ago. Unhooked it and manually tried. There was a spot where it got stuck really hard! Sanded that down and never had a problem since. The old 1/2 HP must have tackled that before but it was a lot slower and louder.
    Back on topic
    Raw Wave
    Nov 2009
    Due you use current sensing, or just crush kids, heads & obstacles? And cats.
    Mar 2004
    Florence Yall, BFKY
    You'd be surprised how many of them don't have current sensing. My old one would have popped a basketball, and that's why the motor burned up.
    I think he wants a sensor for an external circuit though. I used the reed switch, connected to a PIC that converts that to pulses on 2 outputs connected to optocouplers which are connected to a little X10 slimfire remote that my PC receives as on or off, along with an X10 PIR sensor out there so it knows if I'm coming or going.
    The hard part will be detecting the car as soon as it's in the driveway.
    Mar 2006
    Quote Originally Posted by Curiosity View Post
    Magnetic induction loop? Seems simple to me!
  1. Custom USB Parking Sensor interface (formally PDC-USB)
    By Robby BMW in forum Hardware Development
    Last Post: 01-15-2015, 12:51 AM
  2. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 02:35 PM
  3. Infrared Sensor For Garage Door
    By bratnetwork in forum Fusion Brain
    Last Post: 12-05-2008, 10:50 AM
  4. Mass Air Flow Sensor
    By h3rk in forum FB Sensors
    Last Post: 12-16-2007, 04:15 PM
  5. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 04:03 PM
