Page 10 of 170 FirstFirst 123456789101112131415161718192060110 ... LastLast
Results 91 to 100 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #91
    Apr 2010
    @Borte: That is correct.
    @RevheadKev: nrgizerbunny was previously selling the boards alone for 70 and then you still required a Venice chip so I think our price is about right, especially considering the price of the HQCT. I will start taking preorders at a reduced price though in a few days and as you are in Australia, I will give you a discount anyway as I want to get this tested in DAB+ mode as we don't have it here in the UK. I think I am correct in saying Australia is DAB+ only and doesn't support standard DAB?
  2. #92
    Apr 2006
    Sydney, Australia
    The HQCT was that, a device built from the ground up for the car enviroment, you are not really comparing apples with apples. This is similar to the TPMS which was something else turned into a more practical use than just reverse sensors, again this was an expensive item especially for us who's exchange rate determines whether we buy or not.
    As REVKEV said this would kill the option for us locally, but then again with enough people involved we should be able to bang something together far less that the suggested cost from said company..
    Always happy to test as well here in Syd Aus!
  3. #93
    Dec 2007
    Sydney Australia
    Yes Craig, DAB+ and FM only, no DAB.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  4. #94
    Apr 2010
    The unit we have designed is designed specifically for the car environment and tuned for this reason so I think we are comparing apples and more apples actually.
    The thing is, nobody else will never be able to get the Venice chips alone without taking apart old radios. Try contacting Frontier Silicon and you will soon find out the minimum order quantities. The only reason I can get them is through a friend whos company buys them in very large quantities for their own use and thus I am able to buy them in smaller quantities from them.
    @RevheadKev: Can you PM me your email address please and I can sort out sending you out a unit?
  5. #95
    Apr 2010
    Hi i am looking to setup centrafuse in my car but the lack of DAB support has stopped me i would definatly be in the market for this item, when do you think it will be available, i am more than willing to help test
  6. #96
    Low Bitrate fire's Avatar
    Oct 2005
    Melbourne, Australia
    Like RevheadKev and Kosti, i am worried at the price of the unit. We always get shafted with shipping + units that are slightly different for Australia (in this case DAB+ only)
    The most expensive part of the device is the Venice, and that can be found for $60-$70 locally from a doner radio. Venice 7 doesn't offer us much extra over 5.1, and dont see the need in using the 7.
    I have got my doner 5.1, i also have half the parts for the programmer, and need to build the interface board...
    craigbrass, I dont have a problem with what your doing, but because it "may" not work here in Australia, and the limited support we usually get down here, the prices may be too steep for the average joe with a CarPC to hope he gets clear reception..
    The regular DAB+ portable radios sound like a fax machine while driving in some locations, and FM is crystal clear!
    Current Setup - (as per PC specs on the left)
    Future Setup - Commell LV-677, Dual Core2Duo 1.86ghz, 1gb ram, M2-ATX, Morex Mini-ITX case, Transflective screen
  7. #97
    Dec 2007
    Sydney Australia
    Quote Originally Posted by fire View Post
    Hi Fire,
    Would this be ignition interference you think ?
    How does DAB+ sound with engine off ? Clear I would expect.
  8. #98
    Jun 2006
    The main problem is software.
    If the software is standardized across the 5, 5.1 and 7 then there is no problem. Then its just a question of plugging the module in and you are away. The main issue is over here in the UK we don't have DAB+ so there is no way of testing.
    I'll have a think about this one and then come back.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  9. #99
    Oct 2005
    Quote Originally Posted by RevheadKev View Post
    Hi Fire,
    Car on or off while stationary is crystal clear..
    while moving, it sounds like a gargle 10% of the time (even though im using the device's antenna all the way up)... which obviously is not good enough for car use.
  10. #100
    Dec 2007
    Sydney Australia
    Hi Fire,
    Just did some googling and found the following 2 interesting things about DAB+ reception in Australia...
    1. Frequent dropouts were experienced in June 2009 when DAB+ first switched on as many stations apparantly were not broadcasting full power
    2. External antenna vastly improves reception to elliminate dropouts (your gargle)
    Here is a link to an external DAB+ antenna for the Pure Highway unit. Maybe we can source something similar for the Venice modules if they have a connection for it ?
Tags for this Thread
