Page 103 of 170 FirstFirst ... 35393949596979899100101102103104105106107108109110111112113153 ... LastLast
Results 1,021 to 1,030 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1021
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Quote Originally Posted by craigbrass View Post
    http://www.coolapplab.com/ultimate_c...ona/index.html shows the quality of the new board. Build quality and quality of the design is clearly there.
    Agree the new board looks to be a huge improvement, So why then when i just ordered 2 weeks ago did i get the old one?! Without any notice that this would be the case?
  2. #1022
    Apr 2006
    Sydney, Australia
    Quote Originally Posted by HoSS View Post
    really?
    i ordered mine about 1 week or so ago and I only did this to get the new one before the price goes up and our AUD is at a decent level to shop
    id lose it if i get an old one
    New Car PC Build list in progress
  3. #1023
    Apr 2010
    What is your invoice number? I will check it out. I can't tie you to an order with just your username. I had a small stock of old boards I was using to send out to anybody who requested a refund because it was taking too long to get their units to them so possibly you fell into this bracket.
    If it shows at http://www.craigbrasssystems.com/clientarea/ as Pending Dispatch or Awaiting Stock under My Shipments, you'll be getting a new board when they arrive with us around the 20th of this month.
  4. #1024
    Dec 2004
    588 & 686
    So do i understand that in this case you will exchange this?
  5. #1025
    Sep 2010
    Yeah that! I got an old board
    what is the difference other than the massive capacitors not being there?
    I cant even get mine to work, I have tried every option and download in the forum thread and still to no avail. I just get "invalid port selection"
    Anyone have any ideas? I feel like I have wasted a lot of money at the moment. When I pay that amount of money for something I expect it to work without too many problems!
  6. #1026
    Apr 2010
    588 was posted on the 20th of last month and this used the version 1 board. 686 looks like it has been cancelled and refunded - you must of requested this directly with us.
    Well the main difference is an audio driver chip now gets audio first to process it. This improves the sound greatly.
    Can you contact me using http://www.coolapplab.com/contact_us/index.html and I will work with you to get the unit working.
  7. #1027
    Dec 2007
    Sydney Australia
    This "greatly" sounds like a Sales explaination ... no real qualification.
    Craig, all of us with V1.0 boards I am sure are wondering how "greatly" improved the sound is now compared to what our boards produce...
    - is there less noise ?
    - is the signal level higher ?
    - is the channel separation better ?
    - is the frequency response wider ?
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  8. #1028
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by RevheadKev View Post
    I got to say it does confuse many readers. On his site it says :
    Our Ultimate Computer DAB / FM Radio unit changes this. Powered and controlled via USB with audio output via a 3.5mm audio jack to avoid interference
    Now all of the sudden the USB over audio "Greatly" (as you say) improve the sound quality. On his site he make it sound that the USB cable is picking up interference and so decided to use the "3.5mm audio jack" to avoid interference. Im not so sure if I can make any sense out of it.
    I doubt the ADC used is much better than a standard sound card. The only difference is the convenient of having the sound and control are both on the same USB cable. It would be "greatly" if he is taking the digital audio signal directly from the venice 7 and sending them over the USB cable or maybe use the SPDIF.
    When you are trying to sell something, you got to say what you got to say I guess. But cant expect people not to notice when you do that in a technical forum. Im not sure where I saw this "matched pair tantalums" and "each module is tested in sub zero temp, high temp as well as subjected to vibration" to ensure best quality product or something along that line. Its shocking to see a claim on such product when a real HQ product would be too embarassed to claim it.
  9. #1029
    Aug 2009
    UK
    It's a load of bull TBH. The difference is negligible, you'd be hard pressed to tell the difference even in a back to back test. Which I have done.
  10. #1030
    Apr 2010
    In some environments, yes.
    Not really.
    Slightly.
    No.
Tags for this Thread
