Page 11 of 170 FirstFirst ... 2345678910111213141516171819202161111 ... LastLast
Results 101 to 110 of 1696
Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #101
    Low Bitrate fire's Avatar
    Oct 2005
    Melbourne, Australia
    Quote Originally Posted by RevheadKev View Post
    Hi Fire,
    Just did some googling and found the following 2 interesting things about DAB+ reception in Australia...
    1. Frequent dropouts were experienced in June 2009 when DAB+ first switched on as many stations apparantly were not broadcasting full power
    2. External antenna vastly improves reception to elliminate dropouts (your gargle)
    Here is a link to an external DAB+ antenna for the Pure Highway unit. Maybe we can source something similar for the Venice modules if they have a connection for it ?
    I realised that the stations aren't full power.. Same goes for TV.. when analogue is eventually stopped, they will up the power on digital (both radio and TV).
    I will be looking at installing a large antenna when i get the system fully installed in the car (i have a 4wd, so dont mind having a large antenna).
    us Aussies have a long road ahead!
    Current Setup - (as per PC specs on the left)
    Future Setup - Commell LV-677, Dual Core2Duo 1.86ghz, 1gb ram, M2-ATX, Morex Mini-ITX case, Transflective screen
  2. #102
    Dec 2007
    Sydney Australia
    Quote Originally Posted by fire View Post
    Really just waiting on a module we can install and test. Either ready-made or DIY.
    I do quite a bit of travelling upto Brisbane usually each Christmas so between both of us we will have the main eastern australian cities tested well I think.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  3. #103
    Apr 2010
    http://www.dabonwheels.com/Bosch_Bla...ar_aerial.html is the one I use. Just drove about 150 miles in the UK and there was only a short distance of 5m where I had patchy signal but it was between hills so to be expected. Even then, it didn't totally drop out, just breakups every few mins for just a couple of seconds.
  4. #104
    Jun 2006
    you'll need an external aerial to get dab,
    inside a car the signal is basically in a faraday cage so you'll have some issues.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
  5. #105
    Dec 2007
    Sydney Australia
    Graig or nrgizerbunny,
    Does the external antenna have to be specifically for DAB or is there the opportunity to connect and use the standard fm/am aerial from the head unit if the head unit is not installed ?
    I would imagine maybe not with DAB/DAB+ using VHF Band III.
    See details here from WorldDAB (I don't know how old this information is)
  6. #106
    Low Bitrate SoulR's Avatar
    Aug 2007
    Well i am glad to see this continue be it if it takes a more commercial angle.
    I too am in Australia and would be kind to give this a go, i already have a Venice 7 module, would there be an option to use my own module, if so will there be issues with the firmware?
  7. #107
    Jun 2006
    hi kev,
    if you are using a pole antenna, ie one that is telescopic you can alter the length (usually make is shorter), plug in and then it will work.
    If you've got a fixed type such as a beesting you'll need to change the whole thing.
    Visit my Homepage
  8. #108
    Jun 2006
    just one thing to add, you'll need to find out if you've got an amplifier in it.
    Visit my Homepage
  9. #109
    Dec 2007
    Sydney Australia
    Yes nrgizerbunny, the aerial is a short one and it has an amplifier in-line as there is a 12V connection wired to it.
    How does this affect things ?
    I assume from your previous reply that I will need to replace the aerial with a new digital one and remove the amplifier ?
  10. #110
    Apr 2010
    Well I tried an FM aerial and it didn't work even with one of those converter units.
Tags for this Thread
