How about a LED and resistor from the USB SKT +5v line?
Need some help – I have a V7 module from Graig. I modified the rear glass aerial to bypass the FM Amp module and fitted a small matching device to get it resonant at DAB frequencies. I modified my software so that a different Aerial or input is automatically selected when switching between DAB and FM. However the In-Glass aerial is still poor, mainly because it’s horizontally polarised and partly hidden by the roof.
I have been trying to get a good DAB aerial over here in AU but have run into a brick wall.
The Aerial I was looking at is something like a Kinetic DRA-1001. http://www.dabonwheels.com/Kinetic_D...ar_aerial.html However the UK sites do not send this aerial to AU, only the crappy magnetic mount, unamplified unit. Anyone know where I can get a Roof-top aerial like this in AU or anyplace in UK than sends to AU.
Maybe something on here that could help if you havent already checked into it
DVT Forums
Also something u maybe able to hack
Antenna converter
Ryda's Digital Magnet Mount
New Car PC Build list in progress
Thanks for the links; however the Magnetic unit is not going to work in my fringe location.
There is one place in AU that will order the type I am after but at a cost of $215 AU what a %^& rip off.
Have you made sure your FM window aerial does not go through a hidden booster? I bypassed mine but as I said, fringe area and just not good enough. Actually they are marginal on FM to start with, especially as you get away from the city, so I have a dual reason to get a combined base amplified FM-DAB roof mount unit.
not sure if it's going through a booster now as i have removed all of the previous audio gear the car originally was installed with.
Got the file, will test it out and report back
Cheers
Hi Mike
I am interested try your standalone app.Please can you send me download link to martin.kozelsky@centrum.cz
Thank you Martin
I just got my sony xdrs55 radio and the radio module in it does not have a ID on it (see photos).
The module looks like it's been driven by an MCU so it looks to me that it is a slave unit.
Can someone recognize which Venice version (5, 5.1 ,6) this model is and if it is a slave firmare version?
The road is long but we are getting there.
looks like a venice 5 to me.
The epitome of Function over form and is probably the best Car PC in Europe.
Visit my Homepage
Can I plug this on one of Craigs main boards and use it as a slave unit with the venice5 plugin in RoadRunner ?
