The short pins will be no problem because I intend to replace them with longer ones. Will this work as a slave unit with RoadRunner ?
if the pins make contact then it will work with no issues.
Just make sure the pins make contact, you might have to "sand" the female bit on the main board to make sure you get a good contact. The sony venice 5's have short pins.
The epitome of Function over form and is probably the best Car PC in Europe.
Visit my Homepage
The road is long but we are getting there.
So can I use the CD audio in (onboard connector) on motherboard to the jack of the DAB+?
This way I dont have to use the mic in and only get mono
New Car PC Build list in progress
kosti, yea, u have to make a cable, but cd audio in on the mb should work...
prob have to enable that input on your mixer...
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Looking good, Kosti.Just a quick mod to the daughterboard (Venice7 module) as i didnt like the metal screws
Well you could do it at various places with the easiest being the pin 1 and 3 where it connects to the Venice chip.
Contact us using http://www.coolapplab.com/contact_us/index.html and we can get one sent over for you.The Aerial I was looking at is something like a Kinetic DRA-1001. http://www.dabonwheels.com/Kinetic_D...ar_aerial.html However the UK sites do not send this aerial to AU, only the crappy magnetic mount, unamplified unit. Anyone know where I can get a Roof-top aerial like this in AU or anyplace in UK than sends to AU.
Audio over USB won't be happening for a long while, if at all. It adds a lot to the cost and actually causes degrade in quality we have found.
We sell SMB to Motorola connectors when you place your order.
SMB to Motorola cables now available on their own at http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300513377023
