Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1191
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    The new version I received a couple of months back appears to have the boards assembled correctly.
    However take a good look at the adapter when you get it, the SMB and aerial connectors along with the coax were soldered by someone who doesn’t know what they are doing. Apart from both ends shorting causing poor receive (yes it still received) the SMB connector was assembled incorrectly. Apart from that it works great, although I feel the USB to serial interface layout is coupling a small amount of noise (under certain circumstances) into the analogue circuit of the radio.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  2. #1192
    Apr 2010
    presets file
    Was there ever a resolution to this one?
    Right now my radio is stuck on absolute and I am unable to change channels except in FM mode.
    I can scan for new dab channels and find many but still unable to change channel.
    I tried using craigs radio.exe standalone and that works absolutely fine.
    Somewhere there's a c*RruPt3d FiL3 but I have no idea where it is.
    So it looks like we're all gonna have to go and get another venice module now with sony FW if we wanna use CF 3.5 now?
    Cheers,
    tickertapes
    Quote Originally Posted by jdmagoo1 View Post
    OK a i have a bug.
    For whatever reason when i clear the saved station list from within settings it reverts back to the previously saved list.
    For instance, clear the list - re open ultimate radio plugin - list is clear - re scan and add new stations - exit plugin - shutdown & re boot PC - open plugin - previously saved presets are there but not my new ones.
    Now in the mean time is there somewhere i can edit the file manually to clear the list?
    Also in addition to my previous feature request ( first 10 station saved under preset 1 and next 10 under preset 2 and so on) could we have the ability to change the name of the plugin under settings so my display name could be whatever i choose?
    Cheers
    James
  3. #1193
    MySQL Error
    Oct 2004
    you know... CB should at least check in here and let everyone who purchased one he is still involed..
    if i paid for one, and used it with CF, id not be a happy camper, god i hate that saying...
    course if you use it with RideRunner, its a much better experience
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #1194
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    As long as it hasn't blown out a USB port on two laptops
  5. #1195
    Apr 2010
    Hi Andy,
    I'm seriously thinking about going down the slave F/W route as there are issues with the master F/W not to mention the now lack of support in CF 3.5
    A few questions.....
    Do you have any ideas where I can get hold of a V7 module with the sony slave firmware already flashed for sensible money?
    http://shop.ebay.co.uk/i.html?_nkw=s...arr%3D1&_rdc=1
    There are loads of Sony radios available with the 5 or 5.1 modules but I'd like to stick with the 7's for signal sensitivity reasons although they're only very slight.
    Alternatively, are there any sources for the firmware and the flash utility?
    Any help would be great.
    Ta.
    Quote Originally Posted by AndyWhittaker View Post
    Centrafuse 3.5 Plugin v35.1
    What is this for?
    This is for the DIYers who have a Venice 5 module and the Sony slave firmware.
    Changes Since the Last Release
    1. Now supports v3.5 of Centrafuse
    Download the plugin here: DAB_CFv35.1.zip
    Centrafuse 2.x and 3.0, 3.1 Support
    1. None.
    User Manual
    1. None - someone needs to do this or a small explanation how the buttons work.
    BUGS
    1. Various
    2. Needs a new skin to match v3.5
    Future
    Venice 7 coming soon....
    Andy
    ---------- Post added at 06:52 PM ---------- Previous post was at 06:47 PM ----------
    Unfortunately, I think Craig's business model was to always stack up pre-orders before he had actual stock; relying on the fact stock was due to come in - in a timely manner.
    When the stock doesn't come in however.....
  6. #1196
    MySQL Error
    Oct 2004
    we dont really have anything working with venice7 slave code...
    and E, that has nothing to do with riderunner!
    my designed hw doesnt blow out USB Ports
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #1197
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I didn't say it was to do with RideRunner, the CB DAB did that. (I suspect to a badly soldered Cap).
  8. #1198
    MySQL Error
    Oct 2004
    well, you post had my qoute in it, so its misleading
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #1199
    Apr 2010
    Hi Mitch,
    I seem to remember someone saying that the venice 5 / 7 sony slave firmware uses the same commands and were interchangeable. not too sure but I think it was nrgizerbunny.
    Anyway, I'm definately gonna start tinkering a bit myself now and are becoming more convinced that slave mode is the way to go.
    Just out of curiosity, do you have any of your boards left that you'd like to sell?
    regards,
    tickertapes
  10. #1200
    Feb 2007
    Macclesfield, UK
    Quote Originally Posted by tickertapes View Post
    Hi Mitch,
    <snip>
    regards,
    tickertapes
    That was a red herring, the Slave FW for the Venice 7s that I have seen are nowhere near the same as the Venice 5.
    You are correct, the slave firware is the best way to go (IMO). However, I think most people are not equipped to flash their own modules.
    Andy
    Andy Whittaker
    Macclesfield, UK
Tags for this Thread
