Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1271
    Jul 2010
    there's these 2 that could be ok, but i can't see what connector it has on the end..
    http://www.aerpro.com.au/list.php?pc...UGOT+&cat_sno=
    http://www.aerpro.com.au/list.php?pc...EAD++&cat_sno=
  2. #1272
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by Sledge1 View Post
    also, anyone in Aus happen to have a spare SMB to Motorola Adaptor ??
    I have one that I never used as I removed that small PCB mounted socket, put the radio PCB in a shielded case, put a larger socket on the case and ran a new coax lead to the PCB.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
  3. #1273
    Jun 2010
    Syd, Australia
    Just ordered 1 of these units from CB. Wondering if anyone else has put in an order recently? With the lack of communication from CB, I am wondering if I am ever going to receive one. Oh well, paypal gives 45days to lodge complaint if I haven't hear anything
  4. #1274
    Jul 2010
    where are you? did you order the smb to motorola adapter or antenna needed at the same time? (if needed)
  5. #1275
    Jun 2010
    Syd, Australia
    I'm in syd and yeh I ordered adaptor
  6. #1276
    Jul 2010
    ok. getting closer to building this in the car.. but bench testing it now.. Drivers and road runner are installed..
    i can find stations, but can't hear anything.. any idea what i'm doing wrong?
    Standalone program says my 'side by side configuration is wrong'..
  7. #1277
    Dec 2007
    Sydney Australia
    Check the volume level of the module. I set this to 100%
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  8. #1278
    Jul 2010
    is that in the windows mixer for line in properties?
    also, the manual says i can plug directly into the module with speakers... when doing this i still got nothing.. (so that wasn't even going through windows)
    Edit: thanks RevheadKev, got it going
  9. #1279
    Sep 2010
    Quote Originally Posted by tickertapes View Post
    Has anyone tried one of these yet to improve the SNR?
    http://www.olimex.com/dev/pdf/OTHER/USB-ISO.pdf
    Was tinkering over the weekend and discovered that there is a massive ground loop between my antenna & USB. I thought reception was good until I plugged into a floating laptop.
    Available from Farnell and RS for a mere 35 :-)
    I am using one of these-
    http://www.circuitsathome.com/measurements/usb-isolator
    Looks to be the same thing.
    I use it with my USB sound card. I had grounding issues with both my antenna and also the RCA cables from my amps. This fixed my issues.
  10. #1280
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    These two devices “appear” to be different; the first appears to be a HV isolator for the USB interface, the second by dansblackcat appears to be a true ground isolated interface by virtue of the inbuilt isolating transformer.
    That second device could make a big difference to ground coupled noise.
    As a note, it would be wise to confirm that the first device uses a similar circuit and does indeed offer full ground isolation, if so then its a good buy.
Tags for this Thread
