Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1351
    May 2011
    CB Follow UP
    Quote Originally Posted by jeffhills View Post
    Hi
    Does anybody know what has happened to CB? I ordered (and paid) for a unit 3 weeks ago, so far nothing - no replies to emails or 'phone calls. He could be ill, or on holiday, any news would be welcome.
    If CB is just no longer interested, or we need some boards to go back to home build.
    Jeff
    Just got email fron CB letting me know unit on way, looking forward to trying it.
    Jeff
  2. #1352
    Aug 2007
    Dab
    Hi
    i just downloaded your app, and its working just fine.
    i dont know how to search for channels
    on DAB ?
  3. #1353
    ibf
    ibf is offline
    Oct 2010
    Quote Originally Posted by sbasic View Post
    Hi
    on DAB ?
    Press the MENU
    Use the < or > and SELECT until you find something like SCAN/AUTOTUNE or something similiar. Press SELECT and it should scan. You should be able to use FACTORY RESET as well. I cant tell you the exact way as I dont have CB's radio. My test radio has different menu layout.
  4. #1354
    Aug 2007
    Dab
    Only manual tune
  5. #1355
    TBM
    TBM is offline
    Newbie TBM's Avatar
    Jun 2011
    Netherlands
    Thumbs up
    • "Error, Radio Not Found" issue - solved.
    • Echo sound - solved.
  6. #1356
    ibf
    ibf is offline
    Oct 2010
    Quote Originally Posted by TBM View Post
    Im glad its working now. Any problem with the hibernate/standby/resume? I cant test it on my machine as mine seems to crash when putting it to sleep.
    To do : Clean up the code and use the language file. I think thats pretty much it, dont wanna spend to much time on it.
  7. #1357
    TBM
    TBM is offline
    Newbie TBM's Avatar
    Jun 2011
    Netherlands
    Unfortunately, my car-pc crashes as well when using hibernate/standby/resume.
    Have not been able to pinpoint the cause yet.
    M4-ATX / Gigabyte H55N-USB3 / i3-540 / OCZ Agility3 - 60 Gb / W7x64
  8. #1358
    ibf
    ibf is offline
    Oct 2010
    Ok thanks
    Ill just wait for the others to make comments. It should be working OK as it mostly relies on CF managing the audio for it.
  9. #1359
    May 2011
    Unit arrived today, it looks as well made as a 'low volume' item can. Got it up and running as standalone in a few mins, so far cant get it to work in RR (carwings) just get message 'powering on please wait'. I cant find anywhere in config to set port, am I missing something simple?
    Jeff
  10. #1360
    May 2011
    Rr
    Yes i'm stupid, set it in rr.ini. working well now, just need something better than the'bit of wire' to pick up signal
    Jeff
Tags for this Thread
