Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1381
    May 2011
    I tried to select no comport after hibernation. When I did the whole machine hangs. I had to hard reset the machine.
    I think that the comport needs to be released before hibernation and then reconnected after hibernation.
  2. #1382
    Aug 2008
    Thanks all
    Just like to say a big thanks to all involved in this my radio finally works no problems with sound good reception comes on ok after standby works great spent some time testing it on road today the only fault I've noticed us that after the nav speaks it takes about 3-4 seconds before the radio sound comes back but I can live with that so once again a big thanks you have mad this man very happy
  3. #1383
    Jul 2010
    Norway
    The DABRadio pluging from ibf will not work on my carputer. The plugin starts but no sound nor any response when clicking buttons. No error messages either. CBs stand-alone applications is working fine on the same carputer, but I have to press the ON (Power) button.
  4. #1384
    Aug 2005
    Iceland
    I actually feel sorry for u Centrafuse guys, it took mitchjs only few days to make the radio work in RideRunner and I feel sorry for mitchjs because CraigBrass has stiffed him of some payment, i think.
    Has anyone heard from Craigbrass recently, is people receving their units after they order them??
    2005 VW Passat FSI 2.0
    Iceland
  5. #1385
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    For anyone experiencing noise or interference from a PSU or PC and/or noise that reduces disappears when the aerial and/or USB cable is unplugged.
    Try a very short thick ground strap from the shielded case on the DAB receiver to chassis ground.
    The standard board layout does not take this point to ground correctly. Earthing this shield (solder directly to one top edge) allows the receiver to tune and receive weak stations as well as a High quality “stand alone receiver would without the CAR-PC running”. This can also remove any/all residual noise on the audio line. Strange USB and/or aerial ground loop problems appear to be eliminated or greatly improved (assuming other ground and cabling connections are correct).
    If this solution has been posted before then please excuse this posting.
    Surface Pro 2 128GB portrait mode, Win8.1, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE. Previous Car-PC Project
  6. #1386
    Aug 2008
    Something I noticed in my install after installing the plugin you must restart your pc otherwise nothing works correctly and no sound hope this helps
  7. #1387
    TBM
    TBM is offline
    Newbie TBM's Avatar
    Jun 2011
    Netherlands
    Thx Mickz.
    It may have been posted elsewhere but nevertheless interesting enough to mention again.
    I have some noise on the audio line so grounding the shield is definitely worth a try.
  8. #1388
    TBM
    TBM is offline
    Newbie TBM's Avatar
    Jun 2011
    Netherlands
    Quote Originally Posted by 0471430TK View Post
    Did you go into the CF system settings to set the right COM port and recording device for the plugin?
    There are different firmwares used in the CB modules but as far as I understand ibf did take this into account.
  9. #1389
    TBM
    TBM is offline
    Newbie TBM's Avatar
    Jun 2011
    Netherlands
    Quote Originally Posted by Roadwarrior View Post
    I have been in contact with Craig until mid April.
    Did a CF 3.5/3.6 skin for him (with the icon I posted in here as well) hoping this would speed up the release of a plugin.
    Haven't heard from him since.
    AFAIK the units are still send out, in batches.
    This can take quite a while. 2-3 Months is not unlikely.
  10. #1390
    Aug 2005
    Iceland
    Quote Originally Posted by Mickz View Post
    Is it possible to have a photo ??
    Iceland
Tags for this Thread
