Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1401
    May 2011
    I have now finally managed to get the plugin to load correctly after hibernation. I do not know why I had the problem with the plugin but I have two USB-to-serial devices (DAB radio and OBD interface).
    What I did to fix the problem:
    Uninstalled and deleted all USB-to-serial drivers.
    Installed latest drivers from FTDI http://www.ftdichip.com/Drivers/D2XX.htm
    Uninstalled and reinstalled Centrafuse
    Now it works correctly.
  2. #1402
    ibf
    ibf is offline
    Oct 2010
    Quote Originally Posted by TBM View Post
    Thx. Looking forward to any new functionality you can come up with.
    Mono/Stereo with a small LCD icon would be nice... if possible, of course.
    And is the signal strength something that can be made visible with master firmware?
    The V5 FW Im using for testing does have a status output where you can check for power/mode/signal/audio etc etc. In fact I do have a plugin that shows all the info. With CB's V7 I dont think it has a status command, well no one here have mentioned it. Usually a command is sent and the module would output the current status of the module.
  3. #1403
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    Quote Originally Posted by ibf View Post
    The master firmware does not have any status command, the only way to get the status is by decoding the display.
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
  4. #1404
    TBM
    TBM is offline
    Newbie TBM's Avatar
    Jun 2011
    Netherlands
    Quote Originally Posted by Mickz View Post
    The Module was initially mounted in a tiny metal case; this made no difference at all to noise. Locating the module close to the PC has no effect on noise performance if the DAB-module shield is grounded correctly.
    Note: The aerial lead, even if earthed within 3 inches of the socket on the DAB module, will not correctly earth the module with respect to RF interference. The braid in the Aerial lead is a shield; its pretty useless as an RF ground return.
    Recommended mod.
    Less noise and the reception seems improved as well.
    Thanks for posting.
  5. #1405
    ibf
    ibf is offline
    Oct 2010
    Quote Originally Posted by Borte View Post
    I thought as much, it looked like the FW was specially made for a basic radio. Just out of interest did you send a command starting from 0x40 all the way to 0xFF pair with the button release code of course and the module does not reply at all?
  6. #1406
    Jan 2006
    Norway
    It can only respond to button press in the range 0x40 -> 0x80 since 0x0 -> 0x40 means button released. 0x40 -> 0x5F is already described in the interface so I scanned the remaining range from 0x60 -> 0x80 but there was no response at all, it just ignored it.
  7. #1407
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Recommended mod.
    Thanks for posting.
    Thanks for letting others know it helped. It’s such a simple mod but it really does allow the DAB-FM module to perform to it max potential.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
  8. #1408
    Newbie icemanj's Avatar
    Jul 2008
    Brighton, UK
    Hi,
    Well done to all that have contributed to this plug in, I have followed the thread since the start with great interest, being I brought one of these units then updated Centrafuse then to find the DAB unit I only just brought not to work, so was a bit Gutted.........
    I know this is a stupid question and maybe I missed something, but how do you install the plug-in to work with Centrafuse 3.5 as most the plug-ins are downloaded via the app market, is it installed like the old plug-ins where before the app market was available?
    Hope someone can help me as I think Im having a blonde moment lol
  9. #1409
    TBM
    TBM is offline
    Newbie TBM's Avatar
    Jun 2011
    Netherlands
    Centrafuse Directory > Plugins > DABRadio >
    Languages > (English.xml)
    Stations > (station logos)
    Skins > Clean > (skin images and skin.xml)
    DABRadio.dll
    With the above in place and after restarting CF, you should be able to find the DABRadio plugin in the CF system settings. There you can set the COM port and recording device.
  10. #1410
    Apr 2011
    Quote Originally Posted by icemanj View Post
    Hi,
    ... is it installed like the old plug-ins where before the app market was available? ...
    I guess you have to copy it to the plug-in folder ???
Tags for this Thread
