Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1431
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by BIRDMAN View Post
    Hi Guys
    I've just purchased a Creative labs XFI usb external sound card to see if I can overcome the auto mute function on my particular setup. I'll give it a whirl this weekend and I'll let you know how I got on.
    As a matter of interest will does anyone know if nrgizerbunny's PCB accept the later Venice 7 chip ? If so can anyone recommend a suitable cheap donor radio?
    Regards
    Tesco DAB111 for about 25. Make sure its not the DAB111V as it contains the Verona module. I think its discontinued now but Im pretty sure they still sell them in their shops. Its been replaced with a newer model, no idea whats inside, probably a verona as they are meant to be cheaper. Nice little module though.
    A V5 board will take V7. They are pin-pin compatible, the power requirement of the V7 is lower, so there shouldnt be any problems. You will need to flash the FW though, at this point your only option is CB's FW.
  2. #1432
    May 2011
    Venice7 in RR
    Mitch
    Thanks for reply
    1/ never found documentation, sorted now
    2 already set at 1, does not do it much, I think it may be a problem with my audio, I will keep working.
    3&4 shame would, it be possible if I change to V5 slave? whats the support like in RR or should I look into CF?
    Jeff
  3. #1433
    Newbie BIRDMAN's Avatar
    Feb 2010
    Surrey
    Quote Originally Posted by ibf View Post
    Many thanks ibf
    I'm still experiencing the same auto mute issue with the XFI usb sound card installed and onboard sound chip disabled....
    So I think i'll try the venice 7 route as this seems to be sucessfull judging by the posts here. Shame cause everything else on my v5 works 100%.......
  4. #1434
    MySQL Error
    Oct 2004
    Quote Originally Posted by jeffhills View Post
    Mitch
    Thanks for reply
    Jeff
    v5 slave is 1000x more powerfull...and is a complete radio in RR
    CF is way limited of a front end... simple... RR is powerful ...complex
    for #2 maybe i miss read your issue...
    if you want some help pm me
    btw, i wrote all the code for RR v5 and v7
    #3 you can change the color all you want ....
    not font size, too complicated for me to allow it...so i dont
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #1435
    Aug 2005
    Iceland
    Quote Originally Posted by mitchjs View Post
    Would It not be possible to include in RR config program the option of changing the color similar to changing the COM port in drop down window ?
    Less hasle than to change RR.ini manually
    2005 VW Passat FSI 2.0
    Iceland
  6. #1436
    MySQL Error
    Oct 2004
    rw, it is... but the current RRConfig is obsolete
    we are working on a new one, should go public BETA in a week or two
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #1437
    May 2011
    venice 7 in RR
    Mitch
    I will stick with RR then, I have got it to do all I want (apart from phone contacts, but same with CF I think).
    I will re-read thread and try to find radio to get V5 slave and have a play with that, the V7 is working perfectly but missing a few extras.
    Problem 2 was no sound on selecting "RADIO" after power up, the radio was 'on' as station and song data was on screen, I had to go out of radio skin and back in to get sound. This problem has gone away with a different MoBo.
    Thanks again
    Jeff
  8. #1438
    May 2011
    RR venice 5 Module
    I have ordered Sony XDR-S55DAB radio, as donor for V5 to try in RR. I do not have the V5 module in my RR download. Where can I get it?
    Jeff
  9. #1439
    Feb 2010
    Surrey
    Wink
    Quote Originally Posted by tickertapes View Post
    Yep, it's working brilliantly.
    I use Garmin Mobile PC for my Nav and it's cutting in and out exactly as it shoud.
    This is the closest I've been to an OEM NAV/Radio/MP3 solution in terms of quality,usability and reliability but with all the added advantages of a PC.
    tickertapes :-)
    Hi tickertapes
    You wouldn't mind telling me which version files you are using to control your DAB radio V5 chip in Centrafuse 3.6 and where you obtained them from ?
    Regards BIRDMAN
  10. #1440
    MySQL Error
    Oct 2004
    Jeff
    its there, just select it from the installer...
    good luck, you now need a v5 skin, or make your own...
    since not many people have it, i dont think much work is done on it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
Tags for this Thread
