Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1521
    Jul 2010
    Maybe you should think about doing a much larger run...
  2. #1522
    MySQL Error
    Oct 2004
    well with out an assurance of v5/v7 modules i would rather not
    the MINIMUM i would have to do "professionally" is 25 pcs
    im going to hand build these 5, but i dont dare want to do more than that
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #1523
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by jhobrlant View Post
    Yes, I am using your plugin. I was at least in the situation that I received the CB module in time. It was running fine with the standalone the first time. Later I found your plugin. Thanks.
    My setup is a Gigabyte GA-E350 with on-board sound. I am running W7 HP32. Using the on-roof antenna I am using DAB and DAB+ throughout the whole area like shown on the distribution maps. I am not using the FM since this is worse then my car tuner.
    The FM on the venice is not very good compared to a proper HU, but definately better than the silab.
    Quote Originally Posted by Kitiara View Post
    I am using your plugin also, works well for the most part but I do have issues with hibernate (unsure if this is the plugin or CF - does the same thing under CF 3.5 and 4, when resuming windows radio starts buffered instead of live and need to restart to get live radio playing)
    I am running win 7 32 bit with a soundblaster x-fi 5.1 USB sound card
    cheers
    Ok Cheers.
    Im currently on 2 projects at the moment but I will take a look at it as soon as I have the time.
  4. #1524
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by mitchjs View Post
    Im running a small run, very small of the Venice 5/7 USB/audio interface boards
    i prob will have 2 available...
    the problem is the modules, you have to secure you own Venice5 or 7...
    i do have the firmware to the venice7 that has serial control for masters, its not that hard to flash
    but it is a little work...
    i got one v7master module from some tessco dab111 radio... but did have to flash it...
    Is this exactly the same as CB's board? or is this a newer version of the one he currently offers? I guess you made a firmware dump of CB's radio? As for anyone wanting to flash their own, the instruction is at DC somewhere.
    Unfortunately there are too many cheap chinese DAB radio on the market now and venice is no longer the choice for these type of radios, they are only found in the more expensive one. I was checking Tesco a few days ago and they no longer sell the DAB111. It has been replaced by the cheaper one which most likely use the quantek module.
  5. #1525
    Oct 2011
    United Kingdom
    Afternoon guys and girls, I have now started a dispute with paypal to get my money back and nearly through the time alloted for Craig bias to respond they haven't so far!
    So I need an alternative FM / DAB radio for the the UK not worried about AM.
    Any ideas?
    Tom
  6. #1526
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    yoo folks... need some help
    i have a V5... when rr starts debug.txt says:
    Code:
    Venice5---> RadioPowerOn: Create Radio Object
    Venice5---> RadioStart: Com Port COM5 Opened, waiting for ATR
    Venice5---> RadioStart: Radio found on COM5
    Venice5---> RadioPowerOn: RadioOn()
    Venice5---> FmTuneEvent: TUNED to 97,00
    so can can say i have set rr.ini right...?
    but when i fire the BAND command to change from FM to DAB i get:
    Code:
    08-12-2011 00:35:21: Executing: BAND
    08-12-2011 00:35:21: Command not executed: BAND
    I have made a very basic carwings skin:
    Code:
    RideRunner Skin
    RRScreen "radioplayer"
    \images\venice7m_radio_off.png,\images\venice7m_radio_off.png,\images\venice7m_radio_on.png,\images\venice7m_radio_down.png
    L,254,314,277,84,,,,,,=DABNEWSTATION,,
     [Top Bar]
    IMG,87,20,217,36,"\images\DAB+RADIO.png",out
    I,624,009,47,53,"PHONE_CONNECTED_PHOCO"
    I,572,012,50,45,"ONLINE"
    B,006,008,075,52,"MINIMIZE",
    B,674,010,118,52,"EXIT",
    [Main]
    I01,-95,559,73,55,"MASTERMUTE:b"
    B,657,140,140,60,"DABSCAN",
    B,162,224,120,57,"SEEKDOWN",
    B,340,226,120,60,"DABSelect",
    B,517,226,120,57,"SEEKUP",
    B,657,80,140,47,"BAND",""
    I,690,86,31,36,"FMAM"
    I,724,86,43,36,"DABACTIVE"
    I
    L,259,137,267,20,,,,,,=DABSERVICE,,
    L,259,112,267,20,,,,,,=DABFREQUENCY,,
    L,393,164,133,20,,,,,,=DABSIGNAL,,
    L,260,164,133,20,,,,,,=DABBITRATE,,
    A,254,314,277,84,
    A,254,108,277,84,
    [Buttom Bar]
    INC,Bottomtext.txt
    END
    any advice are welcome
    Blessed are the "cracked" for it is they who let in the light.
  7. #1527
    MySQL Error
    Oct 2004
    Quote Originally Posted by ibf View Post
    truth be told, i dont know WHAT exactly his board is, i designed it but turned over the design to him(which he never completly paid for)
    this is my newest and really my only venice5/7 board...
    yes, i have firmware of the tuner from CB...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #1528
    Oct 2008
    Odense, Denmark
    mitch
    any idea what the fault is in my case? sure it's on my shoulders but cant figure what i'm missing
  9. #1529
    MySQL Error
    Oct 2004
    nope... i dont got a v5 to try with
    but "band" is coded in the v5 module
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #1530
    Oct 2008
    Odense, Denmark
    yah... only thing is that nothing happens when i issue the command "band"
    its like stuk on fm at 97.00 like debug says
Tags for this Thread
