Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1531
    MySQL Error
    Oct 2004
    did we test this like year + ago?
    id like to see a debug.txt, is there some other plugins at play?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #1532
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    yep... same module as i shared usb over ethernet when you made the board that some f***er did not pay you for
    just got up but will post the full debug.... but i know for 100% that there is only one radio module installed... venice 5.. checked in radiomodules folder.. only one subfolder
    i made a small snipet from debug since i have rrpdc installed and that makes debug rather large fast:
    Code:
    Venice5---> RadioPowerOn: Create Radio Object
    Venice5---> RadioStart: Com Port COM5 Opened, waiting for ATR
    Venice5---> RadioStart: Radio found on COM5
    Venice5---> RadioPowerOn: RadioOn()
    Venice5---> FmTuneEvent: TUNED to 97,00
    issueing the "band" command via skintool:
    Code:
    08-12-2011 00:35:21: Executing: BAND
    08-12-2011 00:35:21: Command not executed: BAND
    Blessed are the "cracked" for it is they who let in the light.
  3. #1533
    Oct 2008
    Odense, Denmark
    btw.... should the venice5 plugin show up in pluginmgr? just had a faint recall that it was not in there
  4. #1534
    MySQL Error
    Oct 2004
    nope, its not a plugin...
    its a radio module...
    whats rrdpc? sound like you shouldnt use it till someone fixes the debug bloat
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #1535
    Oct 2008
    Odense, Denmark
    RRPDC--- http://www.mp3car.com/hardware-devel...y-pdc-usb.html
    Used to Display distance behind or in front of car... and it writes lines in debug every 2 secs or so... could of course unregister while fixing dab
  6. #1536
    Oct 2008
    Odense, Denmark
    think i have an idea... skin file named wrong
    back in an hour
  7. #1537
    MySQL Error
    Oct 2004
    well... for sure you should be using skintool, NOT a skin file to test stuff you know!!!!!
    i thought you would know that!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #1538
    Oct 2008
    Odense, Denmark
    can confirm that i had the skin file named wrong and skin file was also bad...
    now almost all labels are showing up
    still missing this one: L,254,314,277,84,255,255,255,12,"Arial:B","DABNEWS TATION",,
  9. #1539
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by mitchjs View Post
    nope... first time touching a skin... we all have to learn... but you can have a free laugh
  10. #1540
    Oct 2008
    Odense, Denmark
    screenshot:
    Name:  dab testing.png
    skin file so far:
    Code:
    RideRunner Skin
    RRScreen "radioplayer"
    \images\venice7m_radio_off.png,\images\venice7m_radio_off.png,\images\venice7m_radio_on.png,\images\venice7m_radio_down.png
    [Top Bar]
    IMG,87,20,217,36,"\images\DAB+RADIO.png",out
    I,624,009,47,53,"PHONE_CONNECTED_PHOCO"
    I,572,012,50,45,"ONLINE"
    B,006,008,075,52,"MINIMIZE",
    B,674,010,118,52,"EXIT",
    [Main]
    I01,-95,559,73,55,"MASTERMUTE:b"
    B,657,140,140,60,"DABSCAN",
    B,162,224,120,57,"SEEKDOWN",
    B,340,226,120,60,"DABSelect",
    B,517,226,120,57,"SEEKUP",
    B,657,80,140,47,"BAND",""
    I,690,86,31,36,"FMAM"
    I,724,86,43,36,"DABACTIVE"
    L,259,137,267,20,255,255,255,12,"Arial:B","DABSERVICE",,
    L,259,112,267,20,255,255,255,12,"Arial:B","DABFREQUENCY",,
    L,393,164,133,20,255,255,255,12,"Arial:B","DABSIGNAL",,
    L,260,164,133,20,255,255,255,12,"Arial:B","DABBITRATE",,
    L,254,314,277,84,255,255,255,12,"Arial:B","DABNEWSTATION",,
    A,254,314,277,84,
    A,254,108,277,84,
    [Buttom Bar]
    INC,Bottomtext.txt
    END
    problems:
    1. SEEKUP, SEEKDOWN ,DABSELECT, DABSELECT and BAND does not execute
    2. DABNEWSTATION dos not contain data
    everything is taken from the current commands.txt under documentation/radio modules/venice5
Tags for this Thread
