Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1601
    Feb 2012
    UK
    Hi jerome
    I was surprised that Verona has no shield also, despite the board being marked out for it!
    How are you establishing the software versions, is it a key combination? Apologies if this has been mentioned of the thread before, it is very long!
  2. #1602
    Jan 2012
    Quote Originally Posted by Dabbler View Post
    Hi jerome
    You can read it on the 2x16 display if you go to System then SW version
  3. #1603
    ibf
    ibf is offline
    Oct 2010
    Quote Originally Posted by jerome_ View Post
    Hello,
    I bought a second hand DAB 111 with Venice 7 module
    software version = DAB-mmi-FS2027--0000-0111_v4.0.13.27373-9
    and a new DAB121 for 25 GBP currently available at Tesco with Verona FS2052
    software version = dab-mmi-FS2052-0000-0032_V4.1.14.EX10040-1RC1
    The Verona is a lot smaller and surprisingly does not even have a RF shield.
    I got better sound from the DAB121 but it is probably not related to the modules.
    Now, time to check these I/O signals
    The signals on those I/O wont help you much. They are either connected to the keypad or the LCD screen.
    What you need is the supply, audio out, TX/RX and reset which I have already posted unless you want the pinout for the Venice 7?
    http://www.siliconchip.com.au/cms/A_112141/article.html
  4. #1604
    Jan 2012
    Thanks ibf.
    Between your posts and the siliconchip schematics I got a good pinout of the modules.
    Do you mean that in master mode all the I/O are reused for the user interface ?
  5. #1605
    ibf
    ibf is offline
    Oct 2010
    Thanks ibf.
    The GPIO function are configurable by the firmware so some pins might be used for something like keypad, LCD, amplifier mute line, display dim control etc etc. In our case we are only interested in the pinout of the module in serial control mode.
  6. #1606
    Jan 2012
    Post
    Today I have tried to repplicate the CB radio with the Verona module found into a DAB121.
    These experiments were performed to see what I could get from the module and how to reuse it later maybe. Everything is wired in the air. For a real project I recommend to etch a small board, more reliable.
    The first step is to reprogram the module with a sermmi firmware. The flash is a AT45DB041D. There are plenty of commercial programmers on the market or you can build one yourself. ibf suggests http://dybkowski.net/content/en/node/15 Remember to keep the RESET pin low. You need to erase before re-programming the Flash memory.
    To test quickly the serial communication, I connected the TX and RX pins to a FT232 USB bridge. Open a terminal at 115200 bauds and you can quickly check the effect of the commands and the display update.
    On Verona module you have no pins for I2S signals. But you can pick them, from the DAC (the smallest cheap aboard, check the resistors nearby).
    A couple of interesting posts :
    keys mapping for communication :
    http://www.mp3car.com/hardware-devel...ml#post1439391
    Verona pinout :
    http://www.mp3car.com/hardware-devel...ml#post1468399
    Australian project using a Venice 7 module :
    Many thanks to ibf for the advices and useful links. Good luck for your USB project.
  7. #1607
    ibf
    ibf is offline
    Oct 2010
    Glad its working for you,
    Just to make it clear before someone get confused, the RESET of the module is held low so the module does not try to boot up.
    But on the programmer side as mentioned :
    WARNING: In case of programming Atmel DataFlash memories, RESET signal defined in pinout must be connected with ChipSelect (/CS) line of the chip.
  8. #1608
    May 2011
    V 7 Module
    Finally found my old CB V7 module. I have listed it on Ebay. 130650235193
  9. #1609
    Dec 2006
    Quote Originally Posted by jeffhills View Post
    Bugger....... missed it lol... Thats what happens when you dont check in on a regular basis and to think it was ony a few miles away
  10. #1610
    Feb 2012
    Hacking FS2027 inside Philips AE5230
    By shorting pads inside the venice7 module, I2S signals can be connected back to the following pins:
    pin 24: AUD_MCLK 256xFs 12.288Mhz (pin 4 MCLK)
    pin 25: AUD_SFR Fs 48Khz (pin 3 LRCK)
    pin 26: AUD_SCLK 64xFs 3.072Mhz (pin 2 SCLK)
    pin 27: AUD_SDOUTO (pin 1 SDIN)
    CS4344 is a 10-pin 24-Bit 192kHz stereo D/A converter.
Tags for this Thread
