Like Tree1Likes
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1621
    Apr 2012
    London, United Kingdom, United Kingdom
    Verona Firmware
    So... first post. I've been reading for a while and this forum is a great resource. I'm currently in the process on getting a car PC together and bench testing the software and hardware.
    I have bought the Philips AE5010 Radio from Halfords at a cost of 19.99 and sure enough, inside was the Verona module. I have also built and tested a TTL level to RS232 level bi-directional converter using a max202.
    From what I understand, the next step is to get some useful firmware onto the Verona to enable the Serial in/out ports. I'm at a bit of a loss as to where I acquire the firmware from . I will get onto building a parallel port programmer / buffer as soon as have a source for the firmware.
    I have skipped through this thread from the beginning and have also done so with a similar thread on DC forum. Tying to extract the necessary information from nearly 4000 posts is a little tricky and I would very much appreciate any help anyone can offer.
    Thanks in advance!
  2. #1622
    ibf
    ibf is offline
    Oct 2010
    Quote Originally Posted by Link01 View Post
    Great thread ... but crawling through it I can't find a complete pinout for the Venice 7...
    Does anyone have this? And perhaps a copy of the Frontier reference schematic?
    Or to be specific... anyone know what pin is the brightness control?
    The pin function are dependent on the firmware, so you will need the right schematic for your radio.
    For a V7 with a slave FW this is how the pins are assigned :
    http://www.siliconchip.com.au/cms/A_112141/article.html
  3. #1623
    Apr 2012
    Quote Originally Posted by ibf View Post
    True... but looking at the Frontier module description there is an analogue input that may just have the functionality I would like to exploit already!
    Anyone happen to know what pin it is on?
    Cheers!
    Joe
  4. #1624
    Mar 2010
    I'm having trouble flashing the Verona with sermmi fw, well I'm having trouble dumping the original fw to be more accurate.
    Should the software auto detect the flash chip?
    When I dump the fw all seems to go fine but when I attempt to verify the dump it fails on the first byte.
    Any advice other than check the soldering?
  5. #1625
    ibf
    ibf is offline
    Oct 2010
    The flash chip should be auto detected by the SW, if its not detected then theres something wrong.
    The RESET pin of the DAB module should be connected to 0V so the module does not try to bootup.
    and the RESET from the programmer should be connected to the CS of the DAB module as stated on Adam's site >
    WARNING: In case of programming Atmel DataFlash memories, RESET signal defined in pinout must be connected with ChipSelect (/CS) line of the chip.
  6. #1626
    Mar 2010
    That's possibly what I'm doing wrong then, I have cs and both reset's grounded.
    Thank you.
  7. #1627
    Jan 2012
    The CS# pin of the Flash memory should be controlled by the programmer, as this triggers some internal processes of the memory.
    To check your setup, read the flash memory before attempting anything else. Then open the file with an hexadecimal editor and check for some ASCII strings, like the version. If you have used the radio before, you will also see the list of most recent station names, frequency...appear in the dump.
  8. #1628
    ibf
    ibf is offline
    Oct 2010
  9. #1629
    Feb 2012
    UK
    If anyone is after a Verona module, just to let you know Tesco are still selling the Technika 1101ST on Ebay, item no.270828782975 for 11.49.
    They have sold a LOT, don't know how many they really have left!
    Woah! Just seen my email notifying me that ibf has posted the Tesco deal, spooky! Anyway here's a picture....
    Name:  Technika dab1101st.jpg
    Did finally manage to flash a Verona with the serial MMI firmware and knock up a quick C# program to control it.
  10. #1630
    ibf
    ibf is offline
    Oct 2010
    The 2 links to Tesco are from the raspberrypi forum, LOL small world indeed. TS is one of the member in here I bet.
    Anyway, Tesco have been selling that same radio for many months now. Some of their shop might still sell it. I got it when it was still priced at 19.99 on the shelf, they charged me 9 when I got to the counter.
    You might wanna include a character converter so that the RDS/radio text/DLS... are displayed properly on the PC.
Tags for this Thread
