Page 165 of 168 FirstFirst ... 65115155156157158159160161162163164165166167168 LastLast
Results 1,641 to 1,650 of 1680
Thread: FM/DAB digital radio - THAT WORKS!!
  1. #1641
    Jan 2012
    Quote Originally Posted by Dabbler View Post
    Thanks for the tips jerome, I think I'll go for the split supplies as you suggest. I'm also presuming having separate grounds for the radio and micro sections would be a good idea?
    Split ground is a tricky subject. It can do great good, but it can also be a lot worse if not handled correctly. Unless you are an experienced mixed signal designer, I would recommend you stick to a plain ground plane for your (simple) circuit. Just show us your design and we can comment on it.
  2. #1642
    Feb 2012
    Can anybody send me the SerMMI firmware?
  3. #1643
    Jan 2012
    Has anyone yet measured the current consumption on +1V2 and +3V3 in activity ?
  4. #1644
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by jerome_ View Post
    I dont have the exact figure but its about 50mA for the 1.2V and 100mA for the 3.3V
  5. #1645
    ibf
    ibf is online now
    Oct 2010
    Anyone else built a Verona/Venice based DAB radio for carpc? It seems very quite in here.
  6. #1646
  7. #1647
    Apr 2012
    London, United Kingdom, United Kingdom
    Picked up the project again this weekend and built a simple harness pcb on stripboard. Used the regulators, caps, jack and header from the donor radio and a small inductor from the junk box. Using the 5v pin on the USB/TTL board as a supply.
    Anyway, I plugged in the Verona and my £2.99 Chinese USB/TTL converter and it worked first time Chuffed!
    One thing I have noticed is the serial text display in the Centrafuse plugin seems to lag. If I put the module into standby (so it displays the clock) the time is correct initially, but a few hours later it is an hour behind! The same applies for changing station, if centrafuse has been running for more than a minute of so, the display becomes near enough useless. The preset controls, however, continue to change the stations in real time. The standalone app works fine and the riderunner app was ok when I tried it a couple of months ago.
    Has anyone else made any progress on their projects?
  8. #1648
    Aug 2009
    Have any of you good chaps examined the MonkeyBoard? DAB, DAB+ and FM using a Keystone IC. Couldn't find any reference to it on a site search.
    Link is here
    http://www.monkeyboard.org/products/...elopment-board
    It has VB.NET frontend software and source code and looks pretty damn nice
  9. #1649
    Apr 2012
    Here are some photos of the very simple stripboard harness/shield I made for the verona (see previous post)
    Also, this may be of interest to developers:
    http://www.ebay.co.uk/itm/140819859060
    It is indeed very 'quite' in here!
  10. #1650
    Feb 2012
    UK
    Quote Originally Posted by Powerspring View Post
    Good to see your making progress. Wish I was! On a new project at work which is working me pretty hard, so haven't felt much like 'working' when I get home. But you have given me a nudge.
    Sounds like the Centrafuse plugin is maybe not processing the serial stream correctly. If you run it for hours, does the memory usage go up, as it buffers the yet to be processed messages?
    Quote Originally Posted by mspw View Post
    Link is here
    This looks very very interesting, a module with an api library and sample code. Trouble is its about $110 with postage, then again I've probably spent that much on donor radios :
    I wonder how much the daughter module is on its own?
Tags for this Thread
