Could somebody please send me the V7 sermmi FW?
Cheers.
Edit: Found it on the web. It is part of the latest firmware update for the Philips dcb2070.
Just to say a big "Thank you" to TBM and ibj for the great work of giving life to a "wasted" radio module. So far working great with your plugin in my car!
Cheers.
OK it seems Philips didn't include the DAB firmware on their latest firmware upgrade this time round.
I have actually managed to download the older version a while back which include the "dab-sermmi-FS2027-0000-0359_V4.2.11.38059-1B19.bin" file. I don't recall having much success getting it to work either, the module refuse to boot up (probably a corrupted file)
Venice 9 with slave firmware is the way to go now. Just perfect for carpc DAB radio.
Sony XDR-S56DBP comes with Venice 9 in slave mode, you can buy them cheap on ebay. Venice 9 is not that common and more expensive than the cheap Verona, for people wanting to build a cheap DAB radio Verona cant be beat, they are not bad at all.
Pinout >
Code:3.3V 2 1 1.2V GND 4 3 I2S_SDIN I2S_LRCK 6 5 I2S_SCLK Audio Right 8 7 I2S_MCLK GND 10 9 Audio Left TX (33) 12 11 RX (34) SPDIF 14 13 RESET (39)
Programming pads >
The Venice 9 firmware is compatible with Venice 7 slave firmware and it will work out of the box. You can dump it and flash your Verona like the one here :Code:(SI) (SCK) (WP) (RST) (CS) (3.3V) (SO) (GND)
This Verona is running a Venice 9 slave firmware bolted on a USB Audio + HID board using I2S for audio (you cant see the Verona, its on the underside)
Monkeyboard
USB Verona DAB Radio
Blank PCBs, top and bottom
If anyone interested here is an Argos Value DAB Radio with Verona inside :
dabp-fm-sermmi.ref.ven7_V4.1.14.32300-1
